Too many Kubotas
Who cares if the skid steer is used, but I really like your trailer.CAT 299C - used, of course.View attachment 4637187
Don't give a darn aboot what anyone else thinks.No judgement, enjoy![]()
So I completed assembly of the splitter yesterday. No issues other than a bit of effort routing the hydraulic hoses so there were no interferences when moving the splitter beam to vertical etc. Added engine oil (Castrol Extended Edge Performance 5W-30) and then started filling the tank with CAM2 Promax AW32 hydraulic oil. The first 5-gal pail (white colored cap on pour spout) was light amber and clear, just like motor oil - all good. Opened the next 5-gal pail (grey colored cap on pour spout) and added three to four glugs and noticed the hydraulic fluid to be yellow and cloudy/hazy, and stopped. Opened the third and last container (grey cap on pour spout) and started adding and noticed the same yellow and cloudy/hazy appearance and stopped.Picked up the log splitter today and started putting it together on my trailer. Overall, a heavy weight unit. A couple of minor issues:
Will complete the assembly on my trailer and use my tractor to tow it off the trailer.
- The Honda engine was installed slightly crooked. I loosened the 4X engine mounting bolts and squared it up.
- They recommend the wheel lug nuts be torqued in 3 stages, 25 ft-lb, 40 ft-lb and then 65 - 75 ft-lb. I used 65 ft-lb for the final torque and I thought I was going to snap the studs off. Thankfully, it worked.
- The beam, cylinder and wedge assembly weighs 350 lbs. So I will tackle full assembly in a few days.
View attachment 4582378View attachment 4582379View attachment 4582380View attachment 4582382View attachment 4582383View attachment 4582384
3X 5-gal Napa Premium AW32 hydraulic fluid.So I completed assembly of the splitter yesterday. No issues other than a bit of effort routing the hydraulic hoses so there were no interferences when moving the splitter beam to vertical etc. Added engine oil (Castrol Extended Edge Performance 5W-30) and then started filling the tank with CAM2 Promax AW32 hydraulic oil. The first 5-gal pail (white colored cap on pour spout) was light amber and clear, just like motor oil - all good. Opened the next 5-gal pail (grey colored cap on pour spout) and added three to four glugs and noticed the hydraulic fluid to be yellow and cloudy/hazy, and stopped. Opened the third and last container (grey cap on pour spout) and started adding and noticed the same yellow and cloudy/hazy appearance and stopped.
Called Rural King this morning and let them know. They were fantastic and advised to bring the fluid back and they would credit my purchase price. I will call CAM2 CS this morning and see if anything had changed on their end, etc.
Now I have to drain what I added - a bit over 5-gals and search for alternate fluid. Thankfully, the fluid remains in the tank only and was not circulated. Testing will have to wait.
I haven't used a scope in 8 years. About the most technical tool I use is a voltage meter.A digital Oscilloscope. Had an analog one for years, but that was long gone.
Me too. Got a 2026 GT w/ the Hemi. What about you?Bought a Dodge Durango.
Yup, that's what I got. Had a '19 that I really liked, a GT Plus AWD.Me too. Got a 2026 GT w/ the Hemi. What about you?
