Fastener help
   / Fastener help #11
On our new UTV, the plow set up keeps coming loose. I've already replace the two mounting bolts already, and need to replace one again. I will end up doing both based on info gained here.
The bolts in question are bolted through the mounting bracket into a nut welded to framework. I've already used flat washers and lock washers, but get same result. My next idea is to get bolts that are longer than required, and add a second unwelded nut behind the welded one. The originals had a shoulder like a washer attached to them. Not available around here, so I went with cap bolts with washer and lock washer. Both have failed.
Is my double nut idea a good solution? Note, I can see the welded nuts, but there is very limited room to do anything other than add a nut.
We get snow often here, News just said how it's been years since we've seen so much snow in Dec. so I'm looking to get repaired before next snowfall.
Thanks all
When you say, you added washers. Did you try just a lock washer (split ring?) The proper order is flat (to spread load), then locking, then bolt. Preferred is to leave flat out to prevent any slip.
The longer bolt with locking (jam) nut may be best option for you.
   / Fastener help
Thank you. I used them bolt, flat, locking. Thinking now, and by your statement, I was wrong. The locking against the flat and bracket wouldn't keep bolt from spinning. $10 mistake. I will change to what you said and add the second nut.
That said, the reason I went with flat against bolt was because the bolt head only contacted locking washer about 50%. Right size locker, just the bolt head didn't have much surface area.
  • Good Post
Reactions: D&D
   / Fastener help #14
simple mistake that gets made often. I forgot to add, there is an "old school" option of drilling through the bolt (after install) and dropping in a cotter key. Cheaper than a second nut but bolt and drill size are big factors ;)
   / Fastener help
Thanks, Thought about that already, but there is limited space to work in.
   / Fastener help #16
Like already mentioned loc tite. They make a type that will let you take apart latter or the kind it takes the hand of God to break loose.
   / Fastener help #17
Loctite Blue should do well for you, but the double-nut (also know as a jam nut) idea is a good solution also, as long as the nuts are tightened to each other after tightening the bolt.
Chris
   / Fastener help #18
   / Fastener help #19
Stay away from any fastener that has no grade markings. They are all made of "chinesium" and fail in the most trivial of applications.
Unfortunately, Chinesium bolts sometimes have counterfeit grade markings. (stay away from Amazon!)
To ensure reliability, it is crucial to source bolts from reputable suppliers.
Certifications like API 20E and 20F, ISO 9001:2015, and adherence to ASTM, ASME, and API standards are more likely to deliver genuine, high-quality fasteners.
   / Fastener help #20
Belleville's are great.
I think the king of lock washers is the Nord-Lock. Expensive, but worth it in some applications.
For the OP I'd go with loctite and the jam nut for speed and cost.
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
Towable Dewatering Pump (A59228)
Towable Dewatering...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
