original hydraulic filters wont come off.
   / original hydraulic filters wont come off.
Well after a a 10.0 on the Richter scale it finally came off. LOL I broke 5 filter wrenches in the process
1 with the fabric type band that you guys showed, snapped in a heart beat filter never moved
2 of the metal ones that bind against the filter, I guess i don't know my own strength, not bad a 73 :cool:
2 of 3 prong types that you use a 1/2" long bar bracket. Those were the best but due to their Chinese origin the gears stripped due to my superman like grip.
Finally I drilled a 3/8 hole in the far end and with a long beefy screw driver and the simultaneous cranking with one of those O'Rielly filter metal band wrenches, It slowly came off.
Of course with almost no maneuvering room under neath I had to get my knee against the band and at the same time torque the screw driver
I have never seen the likes of this.
I think it was a combination of Paint 1/16 thick, over tightening, dry gasket and time on the machine before removal.
If Kioti wants to install these like this they should engineer and manufacture a special filter remover taking into consideration the room under the tractor to move any tool.
Phew that was a long story.
   / original hydraulic filters wont come off. #22
Caveman techniques to the rescue ;) Welcome to the club
   / original hydraulic filters wont come off. #23
Yep, this is a long standing issue on Kioti's.
I cheated and had the dealer perform the first service for me. :D :cool:
   / original hydraulic filters wont come off. #25
I was surprised to find that my Branson filters were not painted on.
   / original hydraulic filters wont come off. #26
Nice that you finally got the filter off. Might be a good idea for anyone purchasing a new tractor to get the dealership to crack all the original filters loose and then re-tighten them to correct spec before delivering the new tractor.
   / original hydraulic filters wont come off. #27
I use this when I get the real stubborn filters. Same strap wrench we use to wrap around the flywheel when torquing the flywheel nut at 150 lb/ft
I actually drilled and then used a screw driver of substance :) Not my first choice of how to do things but desperation calls for desperate measures :)
If it had not come off at that i might have brought out the torch and cut the whole tractor in half LOL
Now comes the search for hydraulic oil, I should have paid better attention in biology/ FFA :cool:
   / original hydraulic filters wont come off. #29
I just bought 15 gallons of Triax Agra UTTO
Seems to be well liked. Got a great Cyber Monday deal
   / original hydraulic filters wont come off. #30
Another Caveman...... 🤣
Is it wrong if it works?
Some of my vehicles, the Durango R/T in the current fleet, make engine oil filter swaps a mess if you don't penetrate and drain the can first. I use a sharp awl instead of Sawyer Rob's screwdriver, it punches thru with much less effort, but same concept. I've driven them all the way thru the side wall to spin a difficult filter off, when needed.
And yeah... I know the red Dixie cup (or quart yogurt container) trick. But sometimes a hole in the bottom still proves least messy.
(4) Ratchet Straps (A57453)
(4) Ratchet Straps...
Volvo L306 (A57148)
Volvo L306 (A57148)
CAT 930M (A58214)
CAT 930M (A58214)
Electric Horseless Carriage (A57453)
Electric Horseless...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2003 Hummer H2 4x4 SUV (A56859)
2003 Hummer H2 4x4...
