original hydraulic filters wont come off.
/ original hydraulic filters wont come off. #12
I think a big contributor to stuck filters is installing them without lubricating the seal and engine heat bakes the gasket to the block. Loosening them early, letting a little oil come out is one way to combat this.
/ original hydraulic filters wont come off. #13
I have a set of these:
If I can't get the filter off with a breaker bar, I use an impact wrench.
The trick is finding the right size.
/ original hydraulic filters wont come off. #14
Never really thought about that. Makes sense, as it's pretty universal for end users to lube the gasket when installing a new filter.
Pretty sure they wouldn't at the factory.
/ original hydraulic filters wont come off. #15
That's my theory and I'm sticking to it... ;) plus another beef I have with factory assembly is over tightening fasteners. The shop manual gives a spec on tightening a particular fastener and the factory installation is 2-3 times that spec, stretching threads and generally making removal a real PIA.
/ original hydraulic filters wont come off. #16
Except the fasteners that need to be gorilla tight, like subframe mounts. Seems like they are always just past hand tight.
/ original hydraulic filters wont come off. #17
Interestingly enough, those are the bolts/nuts that the importer/dealer puts on the tractor as the loader mounts, wheels, ROPS and front axle (depending on the size) are installed by the importers/dealers.
I suspect they just send those bolts to the moon using impact guns, then end up stretching the threads and the bolts will never get good and tight again. Others probably just miss the bolts entirely.
/ original hydraulic filters wont come off. #18
Take a long screwdriver and hammer it through the center of the filter, near the base, and get after turning it off!
I bought a tractor that never had the hydraulic oil changed, I had a bear of a time getting the filter off, nearly tore the filter housing off the tractor!
The screwdriver trick has worked every time for me and I've used it a lot..
SR
/ original hydraulic filters wont come off. #19
SR
Another Caveman...... 🤣
Is it wrong if it works?
/ original hydraulic filters wont come off. #20
Well if they don't get tight enough, I'll hammer it home with a big impact :giggle:
Guilty as charged your honor
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
2025 AGT Industrial MX-MRT14 (A60463)
2025 AGT...
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
