John Deere 2720 - Zero Hydraulics, Zero 3-Point Hitch, Zero Answers...
   / John Deere 2720 - Zero Hydraulics, Zero 3-Point Hitch, Zero Answers... #11
Well folks I finally found the problem! There is a seal inside the hydraulic pump (back side) which was blown.
It is the one which wraps around the two shaft ends (if that makes any sense) and prevents the hydraulic oil from diverting from the inlet/outlet portion of the pump.
Did you end up repairing it yourself or dealer?
Any chance you cataloged the repairs with pictures?
   / John Deere 2720 - Zero Hydraulics, Zero 3-Point Hitch, Zero Answers... #12
I know this is an older post but I am having the exact same issue! I am going to pull apart my pump and look. JD doesn't show any break down or seals. Is there anything I should know before I start? Where did you get the seal?
   / John Deere 2720 - Zero Hydraulics, Zero 3-Point Hitch, Zero Answers... #13
I had similar symptoms; in my case, it was a suction hose.
A steel pipe carries oil from the case/ reservoir to the filters, and then (on my tractor) there is a short section of large diameter rubber hose to the hydraulic pumps.
It's buried under things and difficult to see.
And a very cheap fix.
   / John Deere 2720 - Zero Hydraulics, Zero 3-Point Hitch, Zero Answers... #14
I replaced the hose and the two O ring one at each end and it still happening....
   / John Deere 2720 - Zero Hydraulics, Zero 3-Point Hitch, Zero Answers... #15
If the pump is turning, and there is oil at the suction side, then oil must come out of the pressure side unless the pump is broken.
Seals are available from bearing suppliers.
   / John Deere 2720 - Zero Hydraulics, Zero 3-Point Hitch, Zero Answers... #16
Have you checked/cleaned hyd oil suction screen?
   / John Deere 2720 - Zero Hydraulics, Zero 3-Point Hitch, Zero Answers... #17
Yes, I did a full hydro service. Cleaned out the screen and magnets, it was rather dirty.
   / John Deere 2720 - Zero Hydraulics, Zero 3-Point Hitch, Zero Answers... #18
I don’t know anything about a JD 2720. That said with my IH tractor it can/will get air locked when I clean the suction screen.
I have to crack open the outlet of the hydraulic pump to get the air out with the tractor running.
Note the hydraulic oil will spray out, but the air lock is gone.
   / John Deere 2720 - Zero Hydraulics, Zero 3-Point Hitch, Zero Answers... #19
I have a hard time getting the oil to flow after opening the suction side of the system for anything (even filter replacements).
I pressurize the case a little bit with compressed air with the engine running to push it through to the pump.
I have no idea what the "correct" method is.
   / John Deere 2720 - Zero Hydraulics, Zero 3-Point Hitch, Zero Answers... #20
I pulled the pump, both the suction side and the high pressure side were empty. Including the whole pump. It looks like the input shaft seal is bad. I have no idea if this is part of my problem or not.
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2006 Dodge Ram 1500 (A56858)
2006 Dodge Ram...
KUBOTA KX057-5 EXCAVATOR (A52709)
KUBOTA KX057-5...
New Bolt on Receiver (A59000)
New Bolt on...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
