Amazon Stuff That Doesn't Suck
/ Amazon Stuff That Doesn't Suck #81
The HF Hercules grinder accessories are top notch and cheaper than most stores and often Amazon when they’re on sale.
IMPO, Az prices sometimes made to appear as if marked down, but the “mark down” price is the same as our local TSC store price which is no bargain. Point being that sometimes should compare prices at multiple retailers instead of getting sucked down the Az rabbit hole.
/ Amazon Stuff That Doesn't Suck #82
I tried to find an equivalent Hercules wheel Type 29 to the Amazon Benchmark Type 29 wheel. Below are the details on the HF wheel. The only difference that is displayed is 40 grit versus 36 grit and the different compounds.
The Hercules wheel is on sale now at $5.99 each regularly it is $11.99 each.
/ Amazon Stuff That Doesn't Suck #84
Recently on scamazon bought a 2 stroke gas pile driver and one man post hole digger to replace my old 2 man, came with 3 augers and 3 extensions. Both started easily post hole digger worked pretty good for the price, in very rocky soil dug 4, 4" holes with one extension on to place old road sign posts for a bridge I made across a ravine and old collapsed culvert. Drilled holes first than used pile driver to send them at or below frost line. Used some former raised garden bed treated 20' 2x12s for edges/sides. anyways pile driver worked ok despite the rocky soil and old posts I was driving. did have to cut the flared part off about 3 inches of top so it would fit pile driver sleeve. It worked a lot better after I found and reattached the spring tensioner handle nut lol. Luckily I remembered from someone or somewhere turning a pipe wrench around a post hole auger extension in reverse was the only way I could get auger out of ground. 4x 😂 besides about 300 bucks for auger and pile driver that I'm sure I'll use on sandier soil down south on my hobby farm , did spend a little over 6 bucks on lag bolts. Everything else was repurposed. And yeah that's a 60" wide over 1k lb sxs parked on it for size perspective and strength I wanted.
/ Amazon Stuff That Doesn't Suck #85
Hold my na beer lol my bridge made with repurposed junk and cheap scamazon tools held my tiny tractor. With the forks pretty loaded with left over repurposed sign posts and old 2x12s on them. taking a shortcut on bridge I just built to where I store it on a quickly thrown together backwoods rack.
Without so much a creak in the boards or bend in old steel posts on bridge. I'll save testing my tiny tractors seatbelt and rops for another day.
/ Amazon Stuff That Doesn't Suck #86
Question? is there an Amazon or eBay DeWalt 20 volt to 18 volt adapter that is fairly easy to separate battery and or tool from adapter and won't cause a Parasitic drain if after use (out of habit) you left your 20 volt battery in 18 volt tools. The earlier DeWalt brand adapters weren't much to brag about and I expected more from it, unless you left adapter in 18 volt tool permanently and remembered to remove battery after each use.
I don't want to fry a 20 volt battery by accidentally leaving in tool. Yes I've collected quite the inventory of 20 volt batteries and tools over the years. From down state projects on hobby farm . Even though I'm a self proclaimed tool junky Can't really justify spending to get 20 volt tools for my up north cabin especially when I have quite the collection of 18 volt tools that still function fine for smaller projects, however definitely getting tired of using my 18 volt tools minimally and stopping work to wait for a charge. Thanks.
/ Amazon Stuff That Doesn't Suck #87
Cheaters on Amazon you get like a dozen pair for $15 with straps so you don't lose them as frequently as an added bonus they also double up as a food catching snack tray for later use when not wearing lol.
/ Amazon Stuff That Doesn't Suck #88
Found the adapter I was looking for on Amazon inexpensive easy to remove adapter and 20 volt batteries from adapter left this little 2 amp hr 20 volt battery on my 18 volt xrp sawzalll with adapter for a week still full bars so no parasitic drain noticeable. Has not been used or abused much but so far it's lived up to my expectations. I apologize can't find the receipt online but I took pictures of adapter hope this helps if your looking for similar adapters for DeWalt.
/ Amazon Stuff That Doesn't Suck #89
Bought a new starter for my 700 Kodiak off Amazon 1st one I bought was defective and cheaper without a remote solenoid, this one made by this Chinese company works good so far and was 1/3 the price of the oem Yamaha that failed initially. Surprisingly both my 700 Kodiaks starters failed around the same time it mimicked a bad battery very slow cranking speed which wasn't the problem. So I'm getting another of this brand for my up north Kodiak.
Need a couple of crimp connectors in different sizes.
I can get dressed, drive 20+ miles to town and buy disposable bubble packs of five each for $5 each.
Or ...
I can stay in my jammies, click a couple of links and order an assortment of 300 types and sizes in a reusable compartment storage box for $8 and have them brought to me.
/ Amazon Stuff That Doesn't Suck #91
Or ...
I have had to repair a friends truck that he used some Amazon connectors on, eye terminals that were pretty thin material and fatigued and broke off. I have always bought good quality terminals from Digi-Key, McMaster Carr or Terminal Supply as I only like to repair things once.
I'm sure, like all things Amazon, there is a wide range of qualities available, but I never felt like buying them and discovering they weren't good enough for me to use.
Hope you get a good batch.
/ Amazon Stuff That Doesn't Suck #92
I Always buy the heat shrink terminals then I usually put heat shrink over the heat shrink terminals. I also always Do a 5-7 lb pull test on the new connection. .
/ Amazon Stuff That Doesn't Suck #93
Or ...
Depends on how soon you need them. If you can afford to wait a week then by all means order online. If you need them today, better get dressed...
/ Amazon Stuff That Doesn't Suck #94
This is my experience as well. The terminals that I have bought from McMaster, Digikey, DelCity, West Marine have been solid, quality terminals. Most of the Amazon terminals that I have bought seem light lightweight and soft/flimsy. I bought some Amazon bulk refills in large jars that seem ok. YMMV.
All the best, Peter
/ Amazon Stuff That Doesn't Suck #95
All the best, Peter
You really have to do your due diligence when buying anything on Amazon. That said I'm a big fan. Read the fine print and the reviews... then submit some reviews, help the next guy out (y)
/ Amazon Stuff That Doesn't Suck #97
What, your prop rod not made from carbon nanofiber wrapped titanium?
/ Amazon Stuff That Doesn't Suck #98
I am noticing a whole lot of pictures like that over the last year or so. It must be either the minimum wage new hire taking promotional pictures, or someone behind a keyboard doing AI generated garbage.
A recent photo I thought was hilarious was a home water filtration system being showcased on the outside of a house with leaves and snow neatly arranged around the filters. That one was clearly a failed AI.
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A64556)
2021 Mercedes-Benz...
2007 Mack CHN613 T/A Day Cab Truck Tractor (A66736)
2007 Mack CHN613...
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer (A66734)
2023 JCB 3TS8T...
BRADLEY MACHINE  MINI VAC TRAILER (A67714)
BRADLEY MACHINE...
2015 CATERPILLAR D6T LGP HIGH TRACK CRAWLER DOZER (A65056)
2015 CATERPILLAR...
