What grapple fittings do I need?
/ What grapple fittings do I need? #1
turkish
Below is a photo of the 3rd function fittings on the loader of my Kubota MX5800. What fittings on a new grapple do I need to specify? Hoses are 1/2”. Tia.
/ What grapple fittings do I need? #2
These are Pioneer style - with a detent pin. The other choice are the flat skid steer style. Also I like to use a male and female on the machine and the implement so you can plug the ends together wihen not connected.
So I need just to order 1/2” pioneer? They just didn’t look like the ones on my implements I use on the 3pt, so I wasn’t sure.
/ What grapple fittings do I need? #4
Just order two female and swap the one male you have to the grapple. As stated before with a male and female on the implement just connect them together, also it keeps the controls the same.
/ What grapple fittings do I need? #5
I would suggest cleaning off the dirt from the base of the connector and looking for any numbers or brands. Because there are 3 different styles that look very similar, ISO 5675 which is the standard AG connector, but some compacts and other equipment use ISO 7241-A or ISO 7241-B. The 1/2 inch ISO 5675 AG connector will plug into the ISO 7241-A, but will have a flow restriction because of the different lengths of the Poppet tip . Also the slightly different diameter of the tip will over time start leaking.
/ What grapple fittings do I need? #6
Measure them after you google fitting size diagrams. Try learning something new.
Thing is, I spent several minutes googling hydraulic fitting profiles. Didn’t see anything close, so I came here to at least get headed in the right direction.
/ What grapple fittings do I need? #8
The two most common fittings are what was discussed here.
/ What grapple fittings do I need? #9
If you are still unsure, just unscrew the fitting on the tractor and go to; Hydraulic shop, Tractor Supply, Tractor dealer etc, and you can get two female fittings to match - simple.
Success. This is the actual fitting. Faster 2NV-12SAE. Appears to be 7241-A. https://www.motion.com/products/sku...5y61Ieaw5xhkJBG0kxgnoSzXBbs7qBjz677nmofVx5pM2
For Sale L4479 Snowblower and Subframe
For Sale L4479...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
2012 International 4300 Reefer Truck (A61307)
2012 International...
AUCTION STARTS HERE @ 9AM (A62129)
AUCTION STARTS...
JOHN DEERE 5065E TRACTOR (A59823)
JOHN DEERE 5065E...
