Barndominium/Shop or "real" House?
   / Barndominium/Shop or "real" House? #721
I see that your overhead door track follows the slope of roof trusses. Was it a problem to have it installed that way? Do you know if there are limitation on what the slope can be? I would like to do something similar on a steel frame building where the slope is 5:12. Yours looks less steep, at least on the inside.
My barn has a roof pitch above 10:12, and the prior owner had the doors track that way. I re-tracked them horizontally when I added a second floor, but they worked fine previously.
Door spring was torsion type, and doors were old-school vertical planked type with horizontal cleats, so they went up and down as a solid panel, not hinged sections. I guess that's one of the advantages of tracking like that, as a solid panel door might clip something on the way up/down, if tracked horizontally to a low ceiling.
The pitch of the ceiling is 1.5:12. There was no issues having the tracks installed that way. I'm not sure at what pitch it would become a problem if at all. I'm sure the spring/jackshaft components are different if a pitch is greater and the door weight has to be held up in the open position more than say horizontal tracks.
   / Barndominium/Shop or "real" House? #723
As noted, mine is 10:12, and it worked fine. But doors were very wide, I think 10' and 11', which allowed for longer than normal torsion springs.
The trouble you're going to run into, unless you have an electric opener, is spring tension. With a regular or short spring, you'll have trouble putting enough tension into it to keep the door fully open, without having tension so high when closed that the door wants to fly up when not latched down. Esp. if you're heating your garage or trying to keep mice out, you want that door to be under at least a little downward force when down.
Longer springs, whether torsion or extension, allow for a less disparate range of force between open and closed. If door is not very wide, best bet may be longer than standard extension springs, but replacing the usual 2:1 pulley setup with a 3:1 or 4:1 for less range. Of course this means increasing spring strength/force 1.5x or 2x, along with all of the associated fastenings.
   / Barndominium/Shop or "real" House? #724
Since commercial installations of roll up doors exist with vertical tracks: I see no reason that the tracks won't work at any angle you want to put them at. You just need to work out the counterbalance issues. Garage door tracks go horizontal just to clear the garage ceiling, or bottoms of the trusses.
Had to take a break from working on the house and trench for my internet. Spectrum needs to run a plant extension to my meter pedestal. It was going to cost ~$5200 for installation if I had them directional bore the cable to my meter pedestal. If I dug my own trench, $0. Can't argue with $0...
   / Barndominium/Shop or "real" House? #726
We switched to Spectrum fiber optic last year and it's been amazing. Super-fast, reliable and affordable compared to everything else we've had.
Finalizing all the pull boxes, low voltage panel and conduit for internet/network wiring throughut the structure.
One question I have for the electricians out there. The low voltage enclosure has a knockout for a 1 gang outlet box. However, I can't find a box that fills the space. They are all much more narrow than the knockout...
   / Barndominium/Shop or "real" House? #728
View attachment 4434224View attachment 4434225View attachment 4434226View attachment 4434227View attachment 4434229View attachment 4434230View attachment 4434232
Are you sure that knockout isn't for a gland plate?
   / Barndominium/Shop or "real" House? #729
What is the advantage of running the conduit without any wire in it? Why not install the wire now, even if it's not connected to anything.
It's a structured wiring panel with a knockout for an outlet, so you can install the cabe modem in the panel and have an outlet for it. I'm probbaly going to try to fit a network switch in there too. The router will have to go outside the box because the wireless antennas will not work inside the steel enclosure. I may try to put the router in the panel and then use extension cables to antennas inside the attic space.
Rhino DB150 (A57148)
2012 NISSAN AWD Rogue (A56859)
2012 NISSAN AWD...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
LOT: (2) Bucket Hand Pumps: (1) Gear Oil 1/2 Full, (1) Tranny Fluid 1/4 Full (A59076)
LOT: (2) Bucket...
2003 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2003 TRAVIS BODY &...
LOT: (9) Sets of Gutter Broom, 250 KP, Std 26 (5 SEG) (A59076)
LOT: (9) Sets of...
