UTV accessories
/ UTV accessories #41
/ UTV accessories #42
Put some small lights down in the footwells too. You'd be surprised how often you drop something on the floor at night.
Where did you find those? I like that idea since it's dark down there at night. Our windows are heavily tinted. Was it an LED strip?
/ UTV accessories #43
I used the mini eyeball lights that pop into a 3/4" hole.
/ UTV accessories #44
Only thing I've added to my Can-am Defender is a power lead from the battery to the back of the cab. Allows me to plug in my 12 volt sprayer quickly and easily.
Me too. Along with a chainsaw holder, and a piece of 4” pvc unistrutted to the backstop with pressure test plugs to hold a roll of paper towels.
/ UTV accessories #45
Those of you who use a UTV for work, what accessories have you added to make life easier? I know many have lighting, plows, racks etc. What is out of the norm? 110 volt outlets, etc...
2019 Kawasaki Mule SX. The machine arrived with a dealer added windshield & roof. I have added a winch, cargo bed liner, receiver hitch, windshield wiper, cargo area light, driver compartment dome light & roof mounted hazard lights. I never have all the electric accessories on at the same time so no problem with the battery. I have cleared many trails though my 60 acres of forest lane utilizing the mule to carry all the hand tools and other supplies to the site. Now I just drive around maintaining the trails, looking at wildlife and enjoying. The Mule has been bulletproof so far.
/ UTV accessories #46
/ UTV accessories #47
I started with a Bombardier Quad only had dump bed and snow plow 20 years ago. Then kawasaki 610 mule with snow plow and fabric cab and heater. Air cooled engine make lousy heat. After another 5 years
switched to Deere gator with snow plow and and full heated cab. When I got old enough to be forced to start spending my retirement savings, I got a Bobcat Toolcat. Has heat and A/C. You can get attachments
for almost anything. I have dozer blade, snow plow, and combination bucket. Very comfortable. All these have mainly been used to haul yard tools around my 9 hilly wooded acres. If I need 120v someplace I put
EGO portable power station in bed.
/ UTV accessories #48
Rear overbed cargo rack just about doubles useable cargo bed space
/ UTV accessories #49
Not sure how hot your bed gets from the exhaust, but I cut a piece of Styrofoam to fit, and then put a chunk of conveyor belt cut to fit overtop. It at least keeps the birds from cooking back there when out hunting.
/ UTV accessories #50
I made a brush sled/insert for the dump box on my Polaris Ranger for when I haul logs and branches back to the burn pile. It has a boat winch on it so I can secure the load (helpful when going up a hill - DAMHIKT). I made it out of baltic birch plywood and covered it with FRP and aluminum angle.
I also added a diamond plate roof I can stand on when trimming tree branches and a couple light bars for forward and reverse.
In the winter I switch to plowing mode with my Boss plow. The brush sled comes out and I fill the bed with 500 lbs. of concrete blocks and cover it with a cargo cover. That helps immensely when backing up my driveway hill (I plow going downhill).
/ UTV accessories #51
I have not done much yet to my Honda Pioneer 520 that I bought used a couple of years ago.
  • Previous owner put 27x9 tires on it with 1" or 1.5" spacers. Gives a bit of extra ground clearance, which is nice when working in the woods.
  • Winch (installed by previous owner)
  • I added a 66" KFI poly snowplow. Needed a leveling kit on the plow to adjust for the larger tires. I added a roller and strap to double the line from the winch - basically to slow down the winch action when rising and lower the plow.
  • Diamond pattern square link chains on rear tires - needed more traction when plowing snow on our icy hill. Square link is more aggressive than round link chains, but not as likely to damage the small paved section of the driveway up near the house as V-bar or studded chains can do.
  • Added a 2" receiver hitch from Moose Offroad. The stock 1-1/4" hitch was way too low: I would bottom out when crossing rough terrain with anything in the receiver. Plus, all of my existing receiver inserts (I've got a bunch) are 2", so anything I have will now fit the UTV.
  • installed an SAE 2 pin socket in the dash: provides 12 V power for accessories, plus a place to easily plug in my battery maintainer when the UTV is not in use.
  • A couple of 70# bags of sand for the back for better traction when plowing.
I do need to come up with a couple of good chainsaw holders one of these days, to free up some space in the bed.
/ UTV accessories #52
I did the same for a sprayer on my wifes Polaris.
/ UTV accessories #53
Do you think this machine has plenty of power? I know it all really depends on what you expect of them put is the 520 enough for most jobs you ask? I've changing tires size can have a bit of impact on power but so you think it is noticable?
/ UTV accessories #54
For "work" activities I never seem to have enough space for all the tools that I "might" need. Tractor Supply has a double wall roto-molded tool box/cooler with several mounting options. For my Polaris it comes with two large dowels that attach under the lip/flange of the tool box and slip down in the holes that are in the perimeter of my bed.
At first I was disappointed because I didn't consider it a net gain from the area that it robbed from my bed. Then I noticed some rubber spacers that came with it to attach to some other brand, so I attached them to the back of the box and then pulled the box out and turned it around and reinstalled it with the box hanging on the outside of the bed and reclaimed all my space inside. Of course I had to go buy a second one for the other side so it wouldn't look lopsided. Now I've got plenty of storage space.
Just don't forget they're back there when you're cutting corners or trying to squeeze between two trees.
/ UTV accessories #55
I was intentionally looking for a smaller, lighter SxS when I was shopping. I have a tractor for the heavier jobs. I wanted the SxS for when the conditions are a bit too wet/soft to take the tractor out without damaging the trails, or for when I just want to zip out and take care of smaller jobs (or fell trees . I have a polar trailer I used regularly with the Pioneer 520 that is a good match. If I need to haul more than that, I get out the tractor with 3 pt hitch logging winch or haul my dump trailer or log forwarding trailer.
The Pioneer 520 has been a great match for my needs. It's rated to tow 1000#. I still do that (including on my rolling hills) even with the 27" tires. Stock tires were 24", so my 27" tires would increase the top end speed by 12.5%, but decrease torque by the same amount. I've never driven it with 24" tires, so don;t have much to compare it with. I suspect it doesn't make much difference for my uses: if the load is too much, a lower gear takes care of it.
Having said that, If I were buying new, I'd just run the 24" tires for a bit and see how I liked it. I suspect I would miss the greater ground clearance. The stock set up for my 2022 P520 is 8.5". If I were setting it up myself, I'd probably have gone with 26" tires, but I've had no problems with the 27". There is no rubbing in the turns (though some of that is helped by the spacers the previous owner installed).
If I did not have the tractor and were trying to "do it all" with the SxS, I'd probably have gone with a larger unit rated to tow more.
/ UTV accessories #56
Great feedback.
Do you transport it anywhere? If so, on a trailer or can this machine fit in a long-enough truck bed?
/ UTV accessories #57
Great feedback.
I've never tried to get it into a truck bed. The overall width before the spacers were added is 50". In theory, the width would fit in a Ford F150 (which has a bed width of 50.6") but it would be a snug fit. Length might be a problem, since the overall length of the Pioneer 520 is 105" (8' 9").
I haul it in my utility trailer with a 5'x10' bed easily.
/ UTV accessories #58
Great feedback.
So, when we where shopping for a SxS, at the time I only had a 5x10 trailer. According to spec, I though the Pioneer 700 would fit, but it was about 2" too wide with the rear tires. (factory tires). So, we ended up getting a much needed 6'4"×16 trailer anyways.
You do need to watch mission creep, the Viking, 6 seat, starts getting into small Suzuki or Jeep territory, and starts being an issue on trails too.
/ UTV accessories #60
I would say, you won't ever be disappointed in having a 6'4x16 or 7x18 trailer around, so thats $3500 added to the price of the SxS, that you won't regret
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A62131)
UNUSED RAYTREE...
UNUSED JCT DUSTLESS BLASTER (A62131)
UNUSED JCT...
2004 Sterling T/A Dump Truck (A61568)
2004 Sterling T/A...
2015 Freightliner 122SD Truck, VIN # 3AKJGND68FDGH1824 (A61165)
2015 Freightliner...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A59908)
2020 FREIGHTLINER...
Pallet of Fork and Frame Mini Skid Steer Attachment (A61567)
Pallet of Fork and...
