UTV accessories
/ UTV accessories #21
I have a scabbard type holder that mounts to the floor inside the cab, that would have them/it sitting vertical. Have not installed it yet.
I need to attach a mount for my one-handed device. I think I can attach a mount that is designed for wearing on a belt.
  • Good Post
Reactions: JJT
/ UTV accessories #22
Gun rack, both in the cab and one on the back of the cab. Red and white dome light. Front and rear bumpers. The front bumper also has a 2" receiver, that I'll slide a cooler holder into.
/ UTV accessories
I'm going to look into outfitting it with an interior light. I should just buy a dome, but my OCD forces me to spend countless hours researching, and I end up buying one of the first ten I looked at, more often than not.
/ UTV accessories #25
My dome light has two switches, one to turn on bright white, the other turns on a red light, for when I'm night hunting.
/ UTV accessories #26
Our defender came with a dome light but I also put a small blue light ubder the dash so it lights uo the feet area.
Also have a snow plow and cross bed tool box and a 12 volt fridge for trail riding.
Our limited came with a winch, cab, heat and A/C
I did add a windshield wiper delay into the wiper switch.
/ UTV accessories #27
I made a minature version of an over cab ladder rack like most contractors use. Mounts in the pockets of my Polaris Ranger box. Comes in handy for hauling Steel and wood posts, Drain Tile, ladders and branches. By being mounted to the box allows the box to still be dumped. Tool holders are mounted to the uprights to hold Grass trimmers and long handled tools.
/ UTV accessories #28
A buddy picked up a little 12 volt heater that he uses to get the fog off the glass when out in the cold temperatures. I suppose when the windshield is clear, you could turn it towards yourself also.
/ UTV accessories #29
We have heat and AC, we can set the temp just like our truck
/ UTV accessories
Can you share a link of what you went with for lights?
/ UTV accessories
I spent about an hour and half clearing our driveway and my elderly neighbors. Cab was warm enough not to wear gloves, but it isn't cold around here yet, about 31* today. I can see taking doors or windows off for summer, but I'm not trail riding, so not much time inside it.
/ UTV accessories #32
I actually don’t have a link for it. I used to ride Honda Goldwing and it’s it’s like a light that they put on motorcycles kind of hidden lights that just give light on the wheels or on the fenders or on the different body parts, I use that just cause I had an extra light from when I quit riding motorcycle so I just wired it into a a live circuit as soon as I turn the key it turns on
This current Can-Am defender is our fourth one that we bought in 2022 and we have about 6800 miles on it so we use it a lot but we also use it for trail riding. In fact we are going December 6 in Minnesota. There is a winter trail ride that we usually go on
/ UTV accessories
OK, Like an LED light strip. I like that. Off I go to research...
/ UTV accessories
I've seen the younger ones running lights head to toe on snowmobiles up here. That is too flashy for me, but as an interior light, spot on.
/ UTV accessories #36
LED dome light. Hmmmm. Now, I'm thinking I need one too. :D
/ UTV accessories #37
One thing that irks me about my RTVX is the dome light. First, it's in the front, but it doesn't turn on when I open the door, and it's not very bright. I didn't want to have to wire one of the available switches, so I bought a battery-powered LED Dome light that is very bright, which I mounted on the back of the headliner and use Lithium batteries. Here's a link on Amazon Amazon.com
/ UTV accessories
Thanks, my thought was to have it behind me as well.
/ UTV accessories #39
Put some small lights down in the footwells too. You'd be surprised how often you drop something on the floor at night.
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2022 EZ-GO ELITE...
2012 Buick Enclave (A62613)
2012 Buick Enclave...
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
