Hydraulic Top Link NS 6010C
/ Hydraulic Top Link NS 6010C #1
reb0957
Kioti NS4710
Where is the best pace to buy a hydraulic top link for an NS6010C? And what part number?
I didn't realize when I ordered the tractor but the jump to the 60 series they have a Cat 2 3 point.
Thanks!
/ Hydraulic Top Link NS 6010C #2
Look at this link, get the asked for dimension and use that dimension to determine what the mid stroke of the unit should be plus or minus a fraction of an inch.
I recommend a cat 1-2 top link with a 2 1/2" dia cylinder with a 1 1/2" dia rod with a working length of 23 1/4- 35 1/4".
Look at the link, get the pin-pin distance asked for and see what you really need. ;)
/ Hydraulic Top Link NS 6010C #3
Make sure that the toplink that you buy has a stop valve on it. This keeps the piston from leaking down.
/ Hydraulic Top Link NS 6010C #4
i got mine from my local kioti dealer. i like supporting them. want them to stay open..... i also purchased mt 3rd function kit from them, even though they had them cheaper online. we still need to keep the brick and mortar stores open. you could look at Michiganiron also, they post on this site and are helpful people
/ Hydraulic Top Link NS 6010C #5
You could always go chinesium 😂
On a serious note, One thing to look at is the tractor side of your top link to make sure it’s cat 2 also. Many of the Kiotis of that size use a cat 1 on the tractor side. So if you were to order one from somewhere that was a cat 2 on both ends it will more than likely not fit the tractor side.
/ Hydraulic Top Link NS 6010C #6
If there is room for it, you can put a reducer bushing in it.
/ Hydraulic Top Link NS 6010C #7
I bought one of these in Cat 1. No issues. I don't plan on running Cat 2 so I'm just reducing the lowers. At some point I'm going to narrow the lower arm joints and use a Cat 1 Quick Hitch. The Cat 2 lower arm ends is unfortunate.
/ Hydraulic Top Link NS 6010C #8
My ROPS is always in the down position and has a toolbox mounted on it. Under that I installed this simple hook for holding up the the top link when not in use and when swapping out implements.
2022 Kobelco SK85 Excavator (A61166)
2022 Kobelco SK85...
Location Tampa, FL (A61567)
Location Tampa, FL...
UNUSED JCT HYD TRENCHER (A62131)
UNUSED JCT HYD...
2007 Ford Focus Hatchback (A61569)
2007 Ford Focus...
New/Unused Landhonor Mini Skid Steer Pallet Forks (A61166)
New/Unused...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
