If there is room for it, you can put a reducer bushing in it.You could always go chinesium
VEVOR Hydraulic Top Link Cat. 2-2(8-5/16 in, 19-11/16~28 in), Hydraulic Cylinder with 2 Hoses & G3/8" Check Valve | VEVOR US
VEVOR Hydraulic Top Link offers 4 tons of pushing force, high-sealing check valve, and durable 45# steel construction for efficient heavy-duty tractor tasks.www.vevor.com
On a serious note, One thing to look at is the tractor side of your top link to make sure it’s cat 2 also. Many of the Kiotis of that size use a cat 1 on the tractor side. So if you were to order one from somewhere that was a cat 2 on both ends it will more than likely not fit the tractor side.
My ROPS is always in the down position and has a toolbox mounted on it. Under that I installed this simple hook for holding up the the top link when not in use and when swapping out implements.I bought one of these in Cat 1. No issues. I don't plan on running Cat 2 so I'm just reducing the lowers. At some point I'm going to narrow the lower arm joints and use a Cat 1 Quick Hitch. The Cat 2 lower arm ends is unfortunate.
Amazon.com: VEVOR Hydraulic Top Link Cat.1-1 (11 in, 20-7/8~31-7/8 in), Hydraulic Cylinder with 2 Hoses & G3/8" Check Valve : Patio, Lawn & Garden
Buy VEVOR Hydraulic Top Link Cat.1-1 (11 in, 20-7/8~31-7/8 in), Hydraulic Cylinder with 2 Hoses & G3/8" Check Valve: Spare & Replacement Parts - Amazon.com ✓ FREE DELIVERY possible on eligible purchasesa.co
