New garage time!
/ New garage time!
Hello new here
Did you build the cart cab enclosure or is it a factory produced product
Mine is a 1998 48v. They do make and sell rear bed kits for carts, or i wouldn't imagine it would be very expensive.
My kit i think was factory, or maybe after market. It's injection molded plastic, I did not make it. It's a perfect fit though.
There's about a 6" lift as well. I bought the cart about 6mo ago for around $2000 with messed up electrics. I completely rewired it from scratch, and put a new LFP battery in, which cost me about $1000. Upgraded LED headlights, light bar, tail lights, 4way flashers, rear view camera.
You can see the logo on the side, it was a carry-all from the factory. Since carryalls are beefed up, if you want a work cart, you might be better off selling your factory cart and buying a carryall, rather than trying to convert it.
/ New garage time!
Racoons trying to get my chickens...
/ New garage time! #1,564
I appreciate the reply and good idea to keep an eye on the market for the correct application vs re-inventing the wheels
/ New garage time!
If you want to really carry stuff, you might look for a carryall II or III. The difference is the length of the wheel base. The carryall I is basically the same as a club car front to back, which gives it a limited bed size and weight, or your front wheels are going to be coming up. For me, I needed mobility and a very tight turning radius.
Mucking the coops has been much easier. I use a snow shovel, toss it into the back, and then drive to the compost and dump. Before I would use the kubota and bucket, but it wasn't very big and the kubota isn't very agile. Being electric i can just hop in and go. And I can carry a decent load.
/ New garage time! #1,566
possum got our last 2 chickens. Wifey doesn't want more.
We still have the Peahen. She sleeps on top of a tall metal awning car port.
/ New garage time! #1,567
I never heard of possums killing chickens. I didn't even know they could kill a chicken!!!!
/ New garage time! #1,568
Yep, if they are hungry enough. This one climbed up a 6' chain link pen and squeezed thru a 3" gap.
/ New garage time! #1,570
Enjoyed it. Nice that you added all the precursory weed eating and such just to show that there's more to it than just taking the wheel off.
/ New garage time!
Thanks. The wheel is rotted, apparently someone tubed it already. Steiner has new ones for $100.
Hay rides for the kids today, rain held out long enough for me to take them around for a couple hours AND long enough for me to get the hay indoors so I could save and reuse it.
/ New garage time!
Removing a tire suuuuuuuuuuucks without a machine. Breaking the back bead was also not fun. Then it was rusty inside and out so I cleaned up with a high speed grinder. Then I found a steel sheet and started cutting strips on the bandsaw.
Tomorrow I'm going to shape and weld them in place over the hole.
/ New garage time! #1,574
I wouldn't have thought to weld in a patch on a rim, but why not? it's not high speed and all it needs to do is hold a tube.
/ New garage time! #1,575
/ New garage time!
That was my thought. The rest of the rim metal was good. I think water just got in through the valve stem hole and rotted it away.
I cut some strips of steel that I can form to the tire and weld it up.
This is hte unedited verison. The metal bandsaw comes to the rescue again. Although the porta-band makes an appearance. That saw blade is missing teeth, i need to replace it.
/ New garage time!
I could do that too. I'm going to inflate the tube to see what angle it wants to be at.
/ New garage time! #1,579
Can't wait until you finish organizing your new garage ;)
/ New garage time!
Ha, the owner of that garage obviously does not USE his garage. My garage is WELL USED and on a constant rotation of things. I got a surprise 12 bales of hay in the garage, too. Plus kids furniture my wife bought, plus extra solar panels. And my daughters mini that broke down and she bought another car, so now it's MY problem. Stuff, stuff, stuff. It never goes away.
2016 John Deere 6155R (A64119)
2016 John Deere...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
2006 Flori Off Road Dump Truck DF40 (A65579)
2006 Flori Off...
Mini rock grapples (A61567)
Mini rock grapples...
90in. Skid Steer Bucket w/ Blade (A65640)
90in. Skid Steer...
37 Gallon Aluminum Auxiliary Tank (A64127)
37 Gallon Aluminum...
