Can't just retube that
/ Can't just retube that #61
Yup, a split rim not inside of a cage is a good way to loose your head!
I've changed a few, without a cage (didn't have one at the shop!) but we always stood facing the tread, so if it came apart we would be hopefully out of the path of the rim coming apart!
/ Can't just retube that #62
I think you're ready to move on to ether 😜
I think you did a great job. The only concern I'd have is with how the tube might wear a little near the edges of your repair plate. But I'm sure you did as good a job as possible with softening or feathering those edges, and could probably even add body filler later if needed. Probably not any short-term concern, unless the plate edges were left sharp.
I did one better. I wrapped the inside in duct tape! After i ground all the edges as smooth as i could.
/ Can't just retube that #64
We didn't have a cage either. We wrapped a 3/8 chain around the tire and through the centre several times and used an air chuck that screwed onto the valve and was activated about six feet away.
My brother was a firefighter who attended the rescue truck and told us about a call where the split rim exploded and took the top few inches off the workers head.
Well then...
Tires on, holding air. Went to pump up the rear and this is what I found.
It's supposed to look like this:
The stem threads into a piece. Where can I find the stem that threads in?
/ Can't just retube that #66
/ Can't just retube that #67
Well then...
I can't wait to watch you fix this one!!!! I have 200 channels on Directv and this is WAY more interesting!!!
/ Can't just retube that #68
Well then...
I know we're focused on the rim here, but look at the sidewall on the tire. Those big cracks and discoloration don't look good either.
I did the first one because it was tubed. I'm infinitely less confident if the tire isn't tubed. I have no idea if they have tubes or not.
This is the raw, skip to the end as i spent 5 minutes figuring out there was no hydrualic fluid, then 15 minutes adding hydraulic fluid... And I'm kicking myself for forgetting to turn on the microphone.
/ Can't just retube that #70
I love it when a plan comes together!
/ Can't just retube that #71
I don't think I've ever seen a bucket cylinder that has so much travel, and so little effect on the dump and curl functions.
/ Can't just retube that #75
Photo of one my Father fixed.
And another he saved just incase.
/ Can't just retube that #78
2005 20 Ft. Grady-White Boat with 25 Ft. Float-On T/A Boat Trailer (A64557)
2005 20 Ft...
2022 EZ-GO ELITE...
JOHN DEERE 1705 - 6R36" VACUUM PLANTER (A64278)
JOHN DEERE 1705 -...
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
(2) CHROME STEP BARS (A64276)
(2) CHROME STEP...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
