/ Ck2610 Headlight Issue #1
KiotiDKR
Newfoundland
Kioti ck2610
Headlight and related lighting would not come on and was continuously blowing fuses . checked fuse socked and it was shorted to ground . Troubleshooting brought me to the headlight switch . When i was removing this switch the harness / connector was laying on sharp part of the frame and this is where it was shorted . No insulation between harness and frame .. Hope this helps someone with similar issue with light switch .Not the best pic but the white connector is in middle of pic .. this is behind the dash ..View attachment IMG_6060.jpeg
/ Ck2610 Headlight Issue #2
I'm not going to click on it... You click on it. Hey Mikey.
If you’re referring to the link to the pic … sorry don’t know how else to share..
/ Ck2610 Headlight Issue #4
Here it is, cropped down.
/ Ck2610 Headlight Issue #6
Got the invoice for the warranty work. It basically says they replaced the Hydraulic pump, 4 O-rings, Oil Pressure Filter, HST filter, and Hydraulic Fluid.
I'm not sure if the Oil Pressure Filter and Oil Filter are different items though I suspect they are. I'm also not sure where the hydraulic pump is located on the tractor but I'm sure it is not internal if it only took 1 hour to replace. On the other HST tractors I have owned I have replaced the oil but just always figured the hydraulic pumps were internal and never was concerned about them since I had no problems.
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2014 GMC SIERRA 1500 (A62613)
2014 GMC SIERRA...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
Spray King Pull Type Sprayer (A63116)
Spray King Pull...
2019 PALOMINO COLUMBUS 5TH WHEEL (A63569)
2019 PALOMINO...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
