What battery charger do you use?
   / What battery charger do you use? #93
LOL... I have a sears brand from the 70's I believe. Still works fine.
   / What battery charger do you use? #94
2 Battery Tenders and 4 connector cords
   / What battery charger do you use? #95
This one that was passed down to me from my father.
I have a snap on at the other shop that was made by Marquette
   / What battery charger do you use? #97
I've got an old square Schumacher from the 80's or 90's with double length battery clip wires from a donor charger that died. Also have a craigslist Century 6/12v with timer and 200 amp boost.
   / What battery charger do you use? #98
Vevor and NOCO. They have an AGM mode. I have a schumacher SC1300 installed in one tractor but that has simple Lead Acid battery.
What's the big hype with AGM batteries? I get 8 years on Lead Acid batteries.
   / What battery charger do you use? #99
Tony you are doing better than most. The selling point for me is the fact that the cables don’t corrode as bad. I think I got some inferior batteries only lasting two years me keeping them hot on the trickle. And it may be what they are on short living them.
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
Towable Diesel Generator (A59228)
Towable Diesel...
20704 (A55853)
20704 (A55853)
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
