Broken Rear Window replacement
/ Broken Rear Window replacement #1
manzer7
Member
Frenchville, Maine
John Deere 1025R
I broke my rear window on my 1025R 2018 JD Tractor a few weeks ago.
I got a new window for $1,263.81 and put it in myself - no problem.
BUT, I will not buy another one if I unfortunately do it again. I saved the old parts and put it all together again with 1/4 inch plywood and plexiglass.
I hope that it will be just a spare part for if I do break it again. Here are some pics . . . . . . . (Also the tool I made to screw (or hold) the inside nut part.)
Most handy tractor - I had my rake in the ballast box and forgot that it was there when I raised it while the rear window was open !!!!! Oooops ! Expensive rake !!
/ Broken Rear Window replacement #2
my brother in law raised his vertical splitter into the rear glass and managed to bend the hinges without breaking the glass. he got lucky. did you experiment with how big a cutout you can get away with while keeping enough structural integrity. seems like a big difference in visibility.
/ Broken Rear Window replacement #3
Man I thought the rear glass on my Kubota l6060 it was pricey at $450. That's a ridiculous price
/ Broken Rear Window replacement #5
Is that a flat glass panel? It is quite likely a local glass shop could make you a piece of either tempered glass or laminated glass for a lot less.
/ Broken Rear Window replacement #7
If you make one use UV resistant PolyCarbonate, aka Lexan or Tuffak. Much stronger stuff, far more scratch resistant.
/ Broken Rear Window replacement #8
Such a cute little tractor!!!
/ Broken Rear Window replacement #10
Ouch that's expensive, I would love a cab, but the glass wouldn't survive!
Sent from my SM-S921U using TractorByNet mobile app
/ Broken Rear Window replacement #12
I think I would take good look a Lexan IF there's a next time.
/ Broken Rear Window replacement #13
I'm a dummy and got lucky too. I had my Dad's rear blade on my L3540HST and picked it up high. It had a crank at the top to change the blade angle. It had pressure on the rear window when I realized what happened, but didn't break.
I took my angle grinder and cut the sucker off. It was rusted and wouldn't work anyways.
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A63569)
2008 PROGRESSIVE...
SET OF (3) BOX MOUNTS (A63569)
SET OF (3) BOX...
2012 KENWORTH T800 (INOPERABLE) (A63569)
2012 KENWORTH T800...
30ft Highway Trailer Co. Lowboy (A63118)
30ft Highway...
2021 Ford Explorer SUV (A61574)
2021 Ford Explorer...
Patterson water pump (A59230)
Patterson water...
