Leaking NH Injector Pump
/ Leaking NH Injector Pump #1
BeeTrap
Flora, MS
New Hollad TC25D
Hello, I have come here looking for help with a leaking injector pump on a New Holland TC25D. I runs pretty well, but the wife is disgusted with the leak. It can't be helping the tractor either. I am a retired Tool and Die Maker and worked part time, for 21 months, for a tractor repair shop/mechanic. I hate to shell out $500 plus for what may just be an O-ring issue. What lead me here was finding a post about a TC35 Leak. Even if I can't find help with the pump, I am sure that the wealth of knowledge here has to be of a great benefit from now on. Thanks for letting me play in your yard!:dance1:
/ Leaking NH Injector Pump #2
Its definitely an oring..
Prob. the ones under the flange?? Theres a lot more to it than popping it up & replacing an oring.. actually theres 2 on each flange & 1 on the "top nut". {delivery valve holder}
Believe me, I do this for a living, but you can take your chances.
Send me an email if you'd like to get it done professionally.. for a lot less than $500.00..
Those screws holding the flanges down are tamper proof for a reason..
Hello "thepumpguysc", I do understand the complexity of the pump. I have the service and parts manuals for my tractor and have gotten the diagrams from Messick's and the post that lead me to TractorByNet in the first place. Yes, the "5-sided bolts" are a problem. I still can't believe that I could not purchase such a socket even on eBay! Anyway, I would appreciate an estimate from you to rework my pump. I do realize that would be a quote on your "bench fee" and could be higher depending upon work required. Currently I am waiting on a starter for my tractor and would be able to send the pump after I use it to cut our yard again. Thanks for any assistance and your initial response.
/ Leaking NH Injector Pump #4
:welcome:
Welcome to the forum!
I'm going to move this thread over to our New Holland section.
/ Leaking NH Injector Pump #5
Private conversation sent.. no email attached to account..
I have to thank "thepumpguysc". I had sent the injection pump and injectors to him on 08/31/2018 after confirming that he does rebuild injectors also. After a couple of conversations, by email, he had given me several options as far as the injectors go -- rebuild or buy new. I usually defer to what someone would do if they owned the tractor in question. So, yesterday I received the rebuilt injector pump and rebuilt injectors plus the necessary "crush" washers/seals for this. Everything looked great, can't believe the difference in the before and after of the appearance of the parts. Anyway, I got everything put back on, had to use 10" hemostat to get that little evil "CLIP" for the governor arm back on, just glad no one heard my language on that one. Later when it was running my wife came out and she commented on how much better the engine sounded! I have run the tractor for a while, but have not used it yet. I does sound better and I have not seen any leaks -- which was how this all got started anyway. I just want to thank Mike, "thepumpguysc", for his services and would definitely recommend him. I also want to thank TractorByNet, just the source I needed when I needed it.
/ Leaking NH Injector Pump #7
It was a pleasure doing business w/ you.. Happy Tractoring..
/ Leaking NH Injector Pump #8
I apparently have the same problem with a tc25d. Is it difficult to remove the injector pump and then have it fixed by an expert. Then install? Pumpguy are you close to charleston sc?
/ Leaking NH Injector Pump #9
Yes.. I'm in Eutawville.. up by Santee.. I worked in Charleston for 25 years..
Where abouts are u?? Don't tell me.. Johns/James Island??
U can reach me faster thru EMAIL..
I get notifications of a prvt msg. from THIS site at 3am the following day.
So its faster if it drops into my home email box.. I check IT several times a day..
/ Leaking NH Injector Pump #10
I have a New Holland TC29 with an annoying leaking fuel injector pump that I am dealing with and am wondering if you can help me with it.
Thx,
Danny Harris
Conway, AR
/ Leaking NH Injector Pump #11
Yes Danny, no problem at all, I keep the parts in-stock..
Reach out directly at:
My actual screen name ataoldotcom..
/ Leaking NH Injector Pump #12
Thx,
Danny Harris
Conway, AR
Following. I have the same issue.
Bush Hog 3008 (A64127)
Frontier BB5048L (A64126)
Frontier BB5048L...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A65583)
New/Unused AGT...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
