Looking for some info on a Ford 3910 series II from an owner.
/ Looking for some info on a Ford 3910 series II from an owner. #1
Texasmark
Elite Member
N. Texas
Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
I have a 1000 hour Sept 24, 1988 built 3910 Series II and between 1600 and 1800 I get fender rattling vibrations. Other than that you couldn't ask for a better machine. Was wondering if anyone else having the same tractor has the same problem.
/ Looking for some info on a Ford 3910 series II from an owner. #2
Mine in a 1986 with a 1989 engine. I usually have my headphones on listening to 50s, 60s and 70s Rock music stored on my phone. The headphones have noise canceling so my tractor is as quiet as a mouse. ;)
I take it that you don't have the same problem. That's good information. Thanks.
/ Looking for some info on a Ford 3910 series II from an owner. #4
I may. I just never noticed it over the rest of the noise. You could make sure all the carriage bolts are tight as well as the brackets. There's a lot of steel waving off the brackets. I added grab handles to my fenders so I'm usually holding onto one of them for my own stability. My muffler is above the hood. It tends to drown out any would be rattles or the like. With my headphones, I just barely hear the exhaust.
I normally hang on to one of the fenders I installed where you did. Helps me survive the drought terrain rides. The problem I had is basically gone. I bled the lines again and put some Sea Foam (snake oil) in the fuel and it has smoothed out nicely.
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2023 Deere 317G (A60462)
2023 Deere 317G...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61307)
2021 Takeuchi...
2013 FORD F-350 (INOPERABLE) (A60736)
2013 FORD F-350...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
