Do I really need loader float if I have a box blade/rear blade?
   / Do I really need loader float if I have a box blade/rear blade? #1
BadDecisions
Wittmann, AZ
Ford 8N
Old Wagner WM-3 loader on an 8N. Before anyone says it, yes, I'm aware that loader on Ford *N is bad. I've already had this tractor and loader for years, and I rarely use the loader. 99.9% of the time, I used it as a crude crane, and I don't even do that any more since I put an actual crane on my utility truck. Rare enough that it doesn't make sense for me to go buy another tractor for the once every few years I need the loader, and it's simple to install/remove the loader with the crane, so it's only on the tractor when I need it.
A project has come up that I need the loader for...last time I used it, all 3 cylinders were leaking, and it wasn't holding height...so I'm rebuilding the whole dang thing. I see replacement control valves are available with and without float, which I understand make so the loader has neither up or down pressure on it for things like dragging the bucket to grade with it.
I already have a large back blade and box blade that I use for those things, and I THINK the Wagners floated naturally even without a specific float position. The few times I tried back dragging the bucket, it seemed like it would just bounce over the ground, but it's been years since I tried that. I quickly decided the rear blades worked far better than the bucket for grading.
All that said, is there some other reason I should consider getting a float capable control valve?
   / Do I really need loader float if I have a box blade/rear blade? #2
No.
   / Do I really need loader float if I have a box blade/rear blade? #3
Unless there is a huge price difference I would get the valve with float capability. Better to have it and not need it, than need it and not have it.
Doug in SW IA
Doug in SW IA
About a $300 price difference...that's beyond the "well...maybe I'll find a use for it...someday..." break point for me,lol.
   / Do I really need loader float if I have a box blade/rear blade? #5
Does your loader have single acting cylinders for the boom?
If I recall correctly, most of those loaders had single acting cylinders in which case you wouldn't need float, but would recommend a single acting valve for the loader lift.
Sent from my SM-S921U using TractorByNet mobile app
2007 Hyundai Santa Fe SUV (A55973)
2007 Hyundai Santa...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2014 Freightliner MT55 Step Van (A56858)
2014 Freightliner...
2018 Ford F-350 4x4 Ext. Cab Stellar FC3200 3,200lb 1.5 Ton Service Crane Truck (A55973)
2018 Ford F-350...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2008 Ford F-250...
