loader
/ loader #1
Phillip123098
TYM 25 hp, 2014
My loader on my 25hp TYM tractor stopped going higher than 3 1/2 '. I recently changed the hydraulic oil and it's up where it should be. There are no leaks and all hoses seem to be connected. It's 11 yrs old but only 85 hrs and always garaged.
/ loader
I don't believe it has a quick disconnect. I changed the fluid two years ago; there was no indication of air in the system then . Could it be the pump or a clogged filter?
/ loader #6
Pretty sure it does and still believe this is your issue. What model TYM is this?
And to rule out the pump or filter, it would affect other hydraulic functions in the system, not just how high the loader lifts.
/ loader #7
If it raises and lowers, partially, but not full range, starting only after the fluid change; its likely air, IMO. Have you tied end to end cycling it multiple times? Does it have the power to lift front end? Where their symptoms prior to the change?
If it started after only, and you haven't cycled multiple times, up down, up down, curl/dump, a few times; do that and report back.
/ loader #8
Air in cylinders would not prevent the loader from lifting. It would potentially be bouncy but it would still lift to full height.
If pump is starving for oil or sucking air that could potentially limit lifting but typically you will hear the pump cavitating since sounds like rock crusher.
/ loader #9
Loader on the Ford had a Hyd. line Blister in a bend. Pretty much pinched the flow off. Doing fluids and filters NTM.. It sat for ? Yrs.. Old Wagner 4. Suction side to the pump. The tractor ran and that was about it. Replaced that section and with new Fluid and it's been super smooth. Was Slow and Jerky!! There is a filter basket on it that wasn't all that dirty checking it. Seemed Odd?........ Open the pic and you can see the couple inch section.
/ loader #10
Hydralic fluid can get to a point, with some moisture that it builds up a nasty slimy goo, that absolutely can clog up a filter. Im only bringing this up, as it sounds like it sits for long long periods. I dont really think humidity would do that. What did the fluid look like when you drained it?
/ loader #12
How old is this loader to not have a quick disconnect on the hydraulics?
/ loader #13
My Yanmar 1977 model. TYM today the Hyd oil pan was super nasty!!! And stunk INKY. bad. Had a couple inch thick of what looked to be Crisco in a can. The filter screen was in such bad shape I had to replace it. Whale oil had to be. Pre. JD303 To clog up a QC. is doubtful. The fluid would have or had something in it for that to happen. JMO.
/ loader #14
No offense, but im not sure i understand a single thing from that post.
/ loader #15
A fluid flow problem. The QC on a JD. so my guess it's not the problem.
