Thinking about selling dump truck and buying dump trailer
   / Thinking about selling dump truck and buying dump trailer
Im going to hazard a guess that your insurance is the single biggest difference. You already have the ram insured, and, at least here, you may not need an additional policy for the trailer; vs the insurance on the dump truck. Tags are tags, but if offered, a permanent trailer tags is like 5 years worth of cost, for a life time tag.
nah, it’s registration.
Registration on a PA trailer is like 50 bucks. My dump truck is like $1,300 plus fuel sticker and paperwork.
Insurance is like $650/yr on dump truck and literally $0 on the trailer-as you said, insured by the towing vehicle (Ram)
A new dump trailer would presumably be very cheap to maintain for 1st 5+ years. Dump truck more expensive to maintain than trailer.
Another nice thing is I was planning on buying a used trailer for the dump truck to haul excavator. A dump trailer could probably haul my excavator, saving me the need for an equipment trailer.
   / Thinking about selling dump truck and buying dump trailer #22
You may want to run your plan by your insurance company.
   / Thinking about selling dump truck and buying dump trailer #24
I would stick with your dump truck. The largest Big Tex GN dump only has a payload capacity of 23.7 cu. yds and 16,930 lbs. Pricey at $24,595 without a tarp. And with a scissor lift instead of a hydraulic ram. I made that mistake with my first dump trailer, swapped it out for a hydraulic ram trailer after having to shovel dirt out of the front to get it to lift.
I’m pretty much done with the nationally advertised “super trucker” cheapy trailers like that. That’s a light debris trailer.
If I were to find a trailer that suited my needs, it would have a telescoping hoist, not scissor.
I do think the biggest drawback of a dump trailer is the electric hoist compared to the dump trucks rock solis PTO hydraulic hoist.
I’d like to see what Diamond currently offers.
   / Thinking about selling dump truck and buying dump trailer #26
Different sizes and applications, but we sold a dump truck and bought a dump trailer, and eventually sold the trailer and bought another truck. Maneuverability was the reason, as well as dump ability- dump trailers can pretty easily reach their limit where the electric over hydraulic won't lift the load. We're back to a PTO driven dump truck, and won't make the same mistake again.
That’s a valuable insight.
   / Thinking about selling dump truck and buying dump trailer #28
I get what you mean about missing 4WD. Hard to beat that maneuverability, especially in wet fields or tight job sites.
   / Thinking about selling dump truck and buying dump trailer #29
I had an insurance company tell me that while the tow vehicle policy does cover a trailer, there is a limit as to the size and application. Just saying that a phone call may be prudent.
I would also suggest that the weight rating that you are suggesting gets into some serious thoughts as to braking.
Nothing like a 6 wheel dump truck with 4WD to get you where you need to go.
   / Thinking about selling dump truck and buying dump trailer #31
12’ dump with 4’ sides
Another nice thing about a 10 ton dump trailer is the possibility of hauling my excavator with it.
I wouldn’t want to load your excavator into a dump trailer. The ramps are super heavy for one thing. When you get the height of a deckover dump trailer and the weight of a 10 ton excavator the weight of the ramp is even more of a concern. Chaining machines in a dump trailer flat out sucks. Most people just Bluetooth bind them in dump trailers. It’s less of a problem than the previous issues but you can’t spin the machine in a dump trailer either.
It’s not a 10 ton excavator, but I know what you mean. I have my big GN to move it around if needed.
I just figured it’s there in a pinch if needed.
   / Thinking about selling dump truck and buying dump trailer #33
I haven’t had a dump trucks in a couple years. I have 3 dump trailers. I’m mostly using them for dumpsters on my construction job. Occasionally I miss my dump truck but it wasn’t big enough. I really need a tri axel dump if I was going to have one but I can hire the trucking done cheaper than that investment. I miss the ability to tow a machine to the job with the dump truck and then jump right into hauling instead of having to go get a dump trailer first. The dump trailer also takes forever to dump. It’s rare that I would haul over 2-3 loads a day so it’s not a big issue but site hauling like your 200 load log job is painfully slow in a dump trailer.
   / Thinking about selling dump truck and buying dump trailer #34
I honestly would consider the dumpster and roll of type package, if its a lot of demo/debris. You open up a whole other business option, of just dropping a dumpster, and pick up after customer has it full. With that; this isn't an internet ad and cover page decision; and i would Definitely get real world numbers from them; trailer weight, dumpster weight; dump cycle time; dump angle; which they arent going to just list of spec sheet.
I also don't know how enforcement is there; while, yes, your ram and a 25,900 trailer would go though scales/ag stations, around here they are waved through; and generally left alone. Dump truck, most local guys arent harassed either, except certain places (restricted bridges); Motor Carrier Compliance general target OTR guys.
I don’t do much if any, dumpster stuff. I’d rather have a 7 gauge steel bed for rock, logs or stumps.
Yeah not much problem with scales and that nonsense round here, either.
I could do a dump trailer up to 38,000LB, but that’s not really what I want to do.
   / Thinking about selling dump truck and buying dump trailer #36
I want a rolloff truck. But the lighter duty ones don’t haul enough weight. Id want at the absolute bare minimum an F750 that can haul 7-8 tons legally but I’d probably just buy a tandem axle at that point.
   / Thinking about selling dump truck and buying dump trailer #37
Someone must offer a gas engine/hydraulic pump combination for a dump trailer.
I'd be surprised if they made a elec/hyd with enough reservoir capacity for a telescoping cylinder. and I've never been impressed by them for anything much more than a lift gate.
Any chances that you might make some short sideboards for the proposed 24' hay/log trailer for dump truck chores?
   / Thinking about selling dump truck and buying dump trailer #39
Lots of dump trailers are using telescope hoist. They aren’t as big as what a tri axel dump truck uses but they don’t need to be. 2 out my 3 dump trailers are telescope hoist.
KUBOTA U55-5 EXCAVATOR (A59823)
KUBOTA U55-5...
2019 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2019 KOMATSU...
2023 GREAT DANE FLP-0024-00053 53FT FLATBED TRAILER (A59905)
2023 GREAT DANE...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
