Backup camera for tractor
/ Backup camera for tractor #1
AM706
None
Greetings,
Anyone bought a 2 camera system with monitor for their tractor?
I was looking at a wireless, solar camera system that they use for RV's but want one with Android carplay so I can display my tractor telematics from my phone on the monitor as well. Can't seem to find one with the Android feature. I have found dash cams attached to the monitor that have Android carplay but I want to put the front facing camera somewhere so I can see the FEL pallet forks clearly.
Appreciate anyone's advice.
/ Backup camera for tractor #3
I put one on the Bobcat SS. Actually 2 cameras with different views and one monitor with a toggle switch to flip between views. It wasn't hard to install. Just needed to find a key switch power source and a ground. It works great. Rear visibility is almost nonexistent in a SS. One camera sees far and the other sees a wide angle closeup. Very handy. I can now back down the barn center isle if needed. Amazon has a wide selection of RV backup cameras that will do. Buy the best quality picture you can afford.
/ Backup camera for tractor #4
I put one on the Bobcat SS. Actually 2 cameras with different views and one monitor with a switch. Works great. Rear visibility is almost nonexistent in a SS. One camera sees far and the other sees a wide angle closeup. Very handy
Can you provide any detail on the exact system?
/ Backup camera for tractor #5
I've found that it's difficult to mount one or even two cameras on a tractor that will show what you need for all types of work. Powering the cameras is also tricky if you want to avoid running wires. Solar is an option but not for heavily shaded areas or at night. I solved these problems by making my own portable camera system.
I took my existing 2 camera wireless system and modified it to use cordless tool batteries. I added strong magnets so the cameras and monitor could be placed almost anywhere. It's sometimes better to put the camera on or near the work, rather than on the tractor.
This idea will work for most camera systems using an adapter for the brand of cordless tool batteries you use.
I don't always need the cameras, so the magnetic mounts are temporary. Most of the time, the system is in a case behind the tractor seat and deployed when necessary.
/ Backup camera for tractor #6
Not exactly. It's been many years since I purchased the system but searching TFT back up cameras on Amazon brought up something similar here > Amazon.com
The system I bought was around $100 and had only one camera. (best quality picture I could find) I later added a second wide angle hi-resolution camera. I have spent a fair amount of time in a SS in construction and this feature is a game changer.
/ Backup camera for tractor #7
Greetings,
I bought this 4 camera system 9https://www.amazon.com/dp/B0DF7JP228?ref=ppx_yo2ov_dt_b_fed_asin_title )and installed it in my skid steer. I used 3 of the 4 cameras on the rear. No car play, just blue tooth. It was a tight fit in the cab. I used a tackform mount.
/ Backup camera for tractor #9
I installed wireless backup camera a few years ago. Didn't work good-too much interference. Replaced it with wired camera and now works fine.
/ Backup camera for tractor #11
View attachment 4182918 View attachment 4182919
View attachment 4182920 View attachment 4182921
View attachment 4182922 View attachment 4182923
View attachment 4182924 View attachment 4182925
View attachment 4182926 View attachment 4182927
View attachment 4182928 View attachment 4182929
Word of warning: The DeWalt batteries are monitored and controlled by the tool. So, you have to be careful not to over discharge the batteries.
/ Backup camera for tractor #12
Yes, this is true. There is no LVC (low voltage cutoff) in the DeWalt battery BMS. As you say, that function is done by the tool. This is not the case with all brands of cordless tool batteries though.
However, if you do over discharge to the point where the battery will no longer accept a charge, there is a trick to fix the issue. You simply put the dead battery in parallel with a charged one of the same voltage. This puts enough charge in the dead battery for the charger to "recognize" it again.
I've over discharged quite a few over the years and have always been able to get them working again using this trick. Doing this repeatedly will eventually damage the battery though.
/ Backup camera for tractor #14
I put 2 cameras (1 front, 1 back) on my tractor many years ago. The monitor just crapped out last month. I may look for a new wireless system, haven't decided yet.
/ Backup camera for tractor #15
Don't get burned the way I did...I bought a "4 camera system with 7 inch screen" with only one wireless camera included. When I decided to add a rear view I discovered every system and camera uses proprietary protocols - even from the same "manufacturer" or brand. I couldn't buy a spare camera for my system.
When I complained to the vendor they shipped me a "free wireless camera with 4" display". Yay.
/ Backup camera for tractor #16
I vote for a wired camera system also to avoid issues. Easy enough to route wiring in protective sleeve with connector to remove if needed.
/ Backup camera for tractor #19
I just use a mirror
/ Backup camera for tractor #20
Looking at doing the same, and I'm also thinking on getting a canopy so installing the monitor on the canopy would be great.
Seems I have to look at a double row seat golf cart top and make my own brackets to give me the length I want. The standard ones just seem too short. Here in the PNW the rain doesn't just come straight down and would like to keep the rain off my neck.
Bull Horn Decoration (A64127)
Bull Horn...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
17.5X25 industrial tire on Deere articulated loader rim, Coal Valley, IL (A65640)
17.5X25 industrial...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
New/Unused AGROTK YC-32G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
