Deere 4100 blows starter/glow plug fuse when pulling pto switch
/ Deere 4100 blows starter/glow plug fuse when pulling pto switch #1
coloradotrout
Gold Member
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
I had been mowing for an hour when it suddenly died. No dash lights, nothing. I found that the 10A fuse was blown. I replaced it, started right up, but when I engaged the PTO switch, the fuse blew again. Later I installed a 7.5A fuse and mowed for about 30m before the fuse blew. Hydraulic fluid is at minimum on the dipstick. I do have a leak at the fitting attached to the pump. The finish mower was working hard but not stalling.
What can I check?
Another thread noted there are 3 solenoids that may have bad windings. The first time I replaced the fuse it only ran for a few minutes after pulling the PTO switch. The 2nd time it ran for nearly 30 minutes before that fuse blew.
Resistance on the PTO solenoid was 5 ohms. After running the PTO awhile the fuse blew, the solenoid was hot, and resistance 1 ohm. I'm assuming I have a bad solenoid. The spec says 8 to 10 ohms
/ Deere 4100 blows starter/glow plug fuse when pulling pto switch #6
Normally a good solenoid’s resistance would increase with heat. So it sounds like a good possibility that coil is bad. Now for what caused this overheating was most likely dirty clutch plate or maybe worn and too much distance for that coil to pull in. So the entire clutch may need changing. Just some food for thought. Good luck
Thanks. I don't like the sounds of that! Good to know however. It has 2600 hours. Not sure where it's useful life is, but we push it pretty hard. Mowing, tilling and not in easy conditions. The coil got very hot to the touch. But wouldn't an electromagnetic pull to the same spot regardless?
/ Deere 4100 blows starter/glow plug fuse when pulling pto switch #8
Thanks. I don't like the sounds of ! Good to know however. It has 2600 hours. Not sure where it's useful life is, but we push it pretty hard. Mowing, tilling and not in easy conditions. The coil got very hot to the touch. But wouldn't an electromagnetic pull to the same spot regardless?
Colorado trout I’m not sure. Any problems I have dealt with were either a switch or a coil. Looks like the current could be monitored and that would give you an idea where you stand, but I have never did that. I guess if I were you I would buy a solenoid and cross my fingers. Good luck sir
I'm trying a $70 coil from Amazon. JD has a $110 one and a $160 one. We'll see
Ok. Taking the old one off is 10x more difficult than I anticipated. I ground off the coil part. Now I need to remove the threaded piece. But it's recessed in with little clearance to fit a wrench. I may need to fabricate a tool
Cut a 1-1/8" pipe about 10" long. Welded a tiny bead on the insides, filed those flat to match the flat part of the solenoid. Used that as a wrench to remove the old, install the new solenoid.
1-1/8" ID pipe just goes over the solenoid and clears the surrounding areas. I couldn't get any other tools in that space. There's not much torque on the threaded part of the solenoid but access to remove it is very restricted.
2003 Ford F-250 Pickup Truck (A61568)
2003 Ford F-250...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A60352)
2015 Peterbilt 348...
2015 CASE 621F WHEEL LOADER (A58214)
2015 CASE 621F...
