Rocker Switch
/ Rocker Switch #1
HarleyRiders97
Wayne County, Pennsylvania
McCormick CT41
I'm looking for a rocker switch for a McCormick/ Farmall CT41 tractor. The switch is for the lights. It has a red triangle on the switch. The back of the switch has three spots for the wires ( plugs) to be pushed into. Top and bottom are the same size, the middle one is smaller. The numbers have been worn off....any help would be appreciated.
/ Rocker Switch #2
If you can get a schematic that would help. My guess is that one of the wires is hot when you turn on the key. The other two may be to select high or low beam. Good luck.
/ Rocker Switch #4
Can you provide a picture front snd back? Sounds like an SMV switch.
/ Rocker Switch #6
Looks like the part #
245908C1​
Pretty pricey at Amazon
/ Rocker Switch
245908C1​
The back of the switch picture you sent me is not correct, but thanks for replying
/ Rocker Switch #9
This tractor was made by LS. Not sure exactly what model yet but may or may not help with the search.
EDIT: This is possible the correct part number: 40250731 and from Amazon: Amazon.com
No really good pictures of the switch, so it's hard to be sure.
/ Rocker Switch #11
/ Rocker Switch #13
I would wonder if it is just a single pole single throw with the smaller one a ground for the led.
I put a similar one on my wiper circuit on my 2006 silverado so I can shut them off when up and raise them up so they don't freeze in the winter. Some smart engineer made the wipers so you can't raise them in park or shut off up. The fix is finding the arms from another year at the junk yard, I forget which year.
I Read it online in some forum.
Bill
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2016 Chevrolet 2500 HD 4WD (A63118)
2016 Chevrolet...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
International S1900 (A63118)
International...
Location (A63116)
Location (A63116)
