Most economical way to move tractor to dealer
   / Most economical way to move tractor to dealer #31
So... Ya'll are saying if I needed to I could put my gear drive DK45se into neutral and tow it for a distance. Never thought you could get away with that. I could see in a pinch though, maybe. Nah... I think I'd call a rollback.
No, you can't. Do not do this. Across the yard, sure. Down a road, hell no.
   / Most economical way to move tractor to dealer #32
I dunno, on a busy road, a bunch of mad drivers trying to frantically get around you would not be enjoyable at all. And most of us CUT owners are going 10-14mph, max.
Trailering is definitely a chore and a risk, but it's good to keep your skills flexed periodically, I feel.
I, uh, well, I'm weird. :ROFLMAO:
Things like that, they give me a thrill.
   / Most economical way to move tractor to dealer #34
With a "Gear Drive" I see no reason it couldn't be....you'd just need another driver to steer the tractor and work brakes as needed. This is - of course - for a short distance. It's probably not practical, but could indeed be done without hurting anything in the machine. JMO.
   / Most economical way to move tractor to dealer #35
I think Deezler made a good point. It all depends on the road you are doing this on. And I wouldn’t be surprised if someone gets a citation. On second thought I just would not pull it on a public toad
Why do you need to get your tractor to the dealer? Did something break?
Dealer is 45 minutes away and this is only because I can't figure out why my hydraulic pump is leaking. New O-rings. No cracks in the line. Bolts torqued tight. Just can't figure it out and I need to get this tractor back to work.
   / Most economical way to move tractor to dealer #37
If I was closer, I'd haul it for you. Good luck.
   / Most economical way to move tractor to dealer #38
Check the law in your area.
Towing with just a chain is illegal in most places.
BUT, on some roads and for short distances are legal but may also have restrictions.
   / Most economical way to move tractor to dealer #39
I have pulled one of my tractor's a John Deere 5093 E a geared tractor with shuttle shift from a field down the road from my house back to the barn where I could diagnose and work on it under the barn instead of in the dirt, it didn't hurt a thing.
   / Most economical way to move tractor to dealer #40
I have to trailer my DK45 cab to the dealer to have a 3rd function installed tomorrow. I went to grab my trailer…..i forgot i had all that crap stored on it.
I mean theres a dozen 6x6’ fence posts, rolls of non climb fencing, and sacks of concrete. My back was already hurting, so ill have to do it early tomorrow morning before i drive to town.
Instead i washed the tractor and cleaned cab. I dont want the mechanic to think im a slob.
2015 Freightliner Squirt Bucket Truck (A55973)
2015 Freightliner...
JOHN DEERE 900 - 9 SHANK V-RIPPER (A52708)
JOHN DEERE 900 - 9...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58018)
2019 FREIGHTLINER...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2015 Ford F-550 Crew Cab ETI ETC35SNT 35ft Bucket Truck (A55973)
2015 Ford F-550...
