Bent Rotary Cutter Deck - Can it be Fixed?
   / Bent Rotary Cutter Deck - Can it be Fixed? #21
Is there some unpleasantness going on with the two circled welds, or is it just dirt?
   / Bent Rotary Cutter Deck - Can it be Fixed? #22
That thing needs grease for the rear wheel. If it were mine it would be a black mess.
   / Bent Rotary Cutter Deck - Can it be Fixed? #24
I no longer hook up the top link on my mower, I am doing grass trails or hay field, don't need to back over anything and hold the wheel off the ground.
   / Bent Rotary Cutter Deck - Can it be Fixed? #25
They're not surgical. If it spins without hitting or vibrating too much it'll probably cut.
   / Bent Rotary Cutter Deck - Can it be Fixed? #26
Greetings. I was not careful enough when I bought this used Land Pride RCR1248 (heck of a deal!) and did not notice that the deck is bent in a slight U shape on the left side. See the pics with the 6' level. I'm not sure how (or if) it will cut in this condition, but if it does fine I won't worry about it much.
Is there a simple way to bend it back into shape?
Also, it came with a horseshoe shaped top link that I 'think' will work with my quick hitch. Should I be trying to source a floating top link for it, or will it work fine as-is?
Thanks in advance for the help!
Jim
Probably a hot take from me…
But… seeing as there’s no “ring” of dents where rocks get flung up and beat the top up, the paints not all chipped and flaking like you’d see from impacts…
I’d betcha that hawg came that way from the factory.
Send it, and fugettaboutit! ;)🇺🇸
   / Bent Rotary Cutter Deck - Can it be Fixed? #27
The nature of the beast is that rotary cutters get banged, bent and abused. I've straightened, unbent, re-bent, cut, welded...you name it on mine. It still does the job.
Yep,I have a 5"X2" exit hole in the side of my rotary cutter where a blade broke at the bolt. Took a lot of speed and force to make that hole through 1/8" sheet steel. I tried to pound the jagged edges back into the hole but I wore out first.
When it broke the whole tractor and cutter shook violently before I could push the clutch in all the way. During replacing the blades I checked every bolt tightness. All 4 bolts holding the gearbox to the deck were very loose.
Well, the verdict is in...
After ordering a new tailwheel yoke, because, this:
New vs old:
It cut just fine. No noticeable left/right height difference in the cut.
Finally, here's the Messick's floating top link installed to give me the float I needed for my hilly pasture:
Thanks to all for the recommendations!
Jim
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2025 Swict 66in Tooth Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2014 Gravely 60" Zero Turn Commercial Mower (A55973)
2014 Gravely 60"...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
