3 Point Hitch slow and unintended dropping
   / 3 Point Hitch slow and unintended dropping #21
Did you ever find a solution to this? I have the same issue.
I'll suggest to begin your hyd repair procedure by replacing 3 pt rockshaft piston seals.
   / 3 Point Hitch slow and unintended dropping #22
Thank you. This is consistent with what I am seeing and getting for responses.
   / 3 Point Hitch slow and unintended dropping #23
You're welcome
Yes I did. Totally my ignorance, there was no issue at all. What basically happened is that I had changed my top link's attachment position. There's 3 options (attachment holes) on my Kioti and the upper one is the fixed one (which I had always used), i.e. no draft control. During maintenance I had moved it from the upper hole to the lower hole and as such activated the draft control. It states in my manual that in such case the implement will lower automatically. Newby error !
   / 3 Point Hitch slow and unintended dropping #25
LOL...one of those happy it was that kind of error moments!
   / 3 Point Hitch slow and unintended dropping #26
Jim, are you referring to item 5 in this illustration attached?
   / 3 Point Hitch slow and unintended dropping #27
Items #15 and #16. Those are the piston seals with the piston being part #19.
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
PALLET LOF OF WOOD DOORS (A58374)
PALLET LOF OF WOOD...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
VICOR HAY CUTTER (A58216)
VICOR HAY CUTTER...
