Tire Sealant for Slow Leak
   / Tire Sealant for Slow Leak #1
Albert T
Benson, AZ
LS 3038
I have a LS GS3038 with 12.4-24 rear tires. The tire pressure goes from 25 to 0 psi in a week. Are the run of the mill tire sealants like "Slime" good for a tractor tire of this size? I assume a gallon per tire might be required.
   / Tire Sealant for Slow Leak #2
Slime is what I use. Two tractors, one with 14.9-24, one with 17.5-24.
1/2 gallon in each tire. Front tires are 16" and 16.5" with about 1/4 gallon in each.
The fields I mow have a BUNCH of mesquite and thorny (aka honey) locust trees.
   / Tire Sealant for Slow Leak #4
Slime always worked good for me initially then it seems like it went bad and stunk like it was rotten. I have since switched to this and have had no problems. I run it in the atv, utv, skid steer and mower. Haven’t put any in the tractor because Im thinking of replacing the tires.
   / Tire Sealant for Slow Leak #6
I would not use any tire sealant, better to put a tube in. I did use Slime once on a JD 318 I was rebuilding. I put an old tire I had on to replace the rotted out one on it but it leaked down and because I got tired of airing up the tire every time I wanted to move it and did not want to put a new tires or tubes on it until it was finished. The Slime was in there for about 6 months and since I had swapped out the tire before I KNOW the rim was in near perfect shape inside before the Slime was used. The rim was already beginning to pit when I cleaned and painted it.
   / Tire Sealant for Slow Leak #7
Once slime gets old it degrades and will not seal plus no rust protection. Have seen that mess on my on equipment.
   / Tire Sealant for Slow Leak #8
I use Slime in my bicycle and small pneumatic tires with great success. Also used it in a spare tire on my truck. Never tried it in a tractor tire though.
Slime isn't permanent and needs to be added to the tire every couple of years. It's also pretty messy when changing a tire. Water based though, so it's fairly easy to clean up.
Are you sure it isn't a leaky valve stem?
   / Tire Sealant for Slow Leak #9
My tire dealer put this stuff in my front tires ... Tireseal It doesn't seem to go bad/old, and looks kinda like liquid bubble gum!
DEUTZ MARATHON 60KW GENERATOR (A58216)
DEUTZ MARATHON...
LOT OF SHOVELS (A52708)
LOT OF SHOVELS...
2011 Ford F-550 ETI ETCMH37IH 37ft. Insulated Material Handling Bucket Truck (A55973)
2011 Ford F-550...
2016 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A55973)
2016 Freightliner...
John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
John Deere 7230...
LARGE LOT OF CHAIRS & HAND TRUCK (A58374)
LARGE LOT OF...
