Spray On / Rinse Off cleaner and degreaser.
/ Spray On / Rinse Off cleaner and degreaser. #21
It has been my experience after decades of washing cars, house siding, motors, and other objects that a water rinse, even from a 1500 psi pressure washer, leaves a residue after the water dries, but physical disturbance by a brush or even a rag while the surface is wet and before the final rinse removes that residue. I would describe the effort as brushing rather than scrubbing although scrubbing may be necessary. If the OP has globs of dust caked grease, a quick scraping with a putty knife may be more effective and less total effort than multiple washings.
Simple Green Extreme is the only product I'm aware of that is safe for aluminum. It is specifically formulated to clean airplanes.
/ Spray On / Rinse Off cleaner and degreaser. #23
/ Spray On / Rinse Off cleaner and degreaser. #25
If you are doing smaller areas, oven cleaner also works.
Yep. Back in the day, when I did not have a pressure washer, I degreased an entire tractor with about 10 cans of el-cheapo oven cleaner from Walmart. I'd spray an area, let it work overnight, and hit it with a garden hose the next day. It worked extremely well.
/ Spray On / Rinse Off cleaner and degreaser. #26
I won a bucket of accesories at a car show recently and in it was a bottle of Spray 9. It's my go-to now. Really dissolves the stuff.
Mostly been using it to clean the grills in my electric smoker. When the bottle ran out I bought a one gallon refill on Amazon.
/ Spray On / Rinse Off cleaner and degreaser. #27
I'm on well water so any chemicals (cleaners and oils) and wash water I use just end up in my drinking water.
I wipe off grease with an old rag and dispose of as household hazardous waste.
The moment you use water a cleaners to remove grease you take a concentrated pollution problem and turn it in a big diluted contaminated water problem.
/ Spray On / Rinse Off cleaner and degreaser. #28
I use Simple Green. For you Snow Birds heading to Florida it also works Great on the Love Bugs on the front of your car- no scrubbing /
/ Spray On / Rinse Off cleaner and degreaser. #29
Is your well 3 feet below grade? I understand not wanting to dump out used oil straight into the ground, or barrels of toxic hazardous waste, but simple green, or even Dawn dish soap are environmentally friendly, and the cup or 2 of grease that will come off the tractor is nothing. Soil is an amazing filter, you know it takes about 6 feet of soil to turn human waste back to water?
I start with Dawn & a plastic/nylon brush, then go to harsher cleaners as needed.
/ Spray On / Rinse Off cleaner and degreaser. #30
Raccoons shiit where they sleep.
Dilution isn't the solution to pollution
/ Spray On / Rinse Off cleaner and degreaser. #31
LA’s Totally Awesome. Use it in all my equipment to get off dirt and grease. Can get it at Dollar General
Actually works pretty good and it's low cost
OP: Grease covered with dirt prevents rust tho
/ Spray On / Rinse Off cleaner and degreaser. #32
A cup of petroleum based grease, isn't going to destroy the planet, I mean, that's where it came from in the first place... And I don't see how the 2 rolls of paper towels you blow through is helping anything, still needs to be disposed of, you think the garbage/recycling plant is picking out all those paper fibers so it can recycle the grease?
/ Spray On / Rinse Off cleaner and degreaser. #33
ooooh they look so cute honey that's why I'm feeding them on my porch
/ Spray On / Rinse Off cleaner and degreaser. #34
I don't disagree but the ground with its natural filtration sediments and its microbes are quite resilient and are a natural filter for even some of the worst chemicals. Water itself is the most used chemical solvent in the world.
My well is 600ft with the water level around 250. The casing I believe goes down to 300ft so any water introduced into the well starts at 300ft.
With that said, no I do not condone continuous contamination of the same area but occasional cleaning with most of today's cleaners isnt an issue.
What if you simply use a citrus based degreaser? That doesn't neutralize the stuff you are cleaning off.
Which leads me to the subject of disposing of used motor oil. I just pour it on the ground cause hey, isnt that where it came from? (Kidding).
/ Spray On / Rinse Off cleaner and degreaser. #36
Not directly relevant, but I used Simple Green both on my tractor, where I had some oily residue and my garage floor--I used to have Harley Davidsons, which "marked their territory," so I had a number of oily stains. I mixed it about double strength, applied it by way of my pressure washer, let it set for 15 minutes or so, then rinsed. It worked quite well.
/ Spray On / Rinse Off cleaner and degreaser. #37
I use Gunk and a power washer.
/ Spray On / Rinse Off cleaner and degreaser. #38
Brake cleaner works quickly and well for most, won't hurt anything & may be something you already have. A little gasoline does the job also & the odor goes away quickly when cleaned off. Certainly the spray degreasers can do the job, but require water & $ to buy something extra.
/ Spray On / Rinse Off cleaner and degreaser. #39
Maybe remove gunk with Gunk?
Bruce
They used to make better stuff. Brake Cleaner is my go to and I don't over grease my spindles. I change the oil in my X320 JD and save it. I remove the deck and turn it upside down cleaning dirt and rust as much as possible with a putty knife.
I move it to a gravel area and pour the used oil into it, mopping to all areas and leave it overnite.
/ Spray On / Rinse Off cleaner and degreaser. #40
Most of if not all the above are ok but not so good for the earth.
No, I'm not a eco-nut. Just cautious. If it will dissolve grease that
great, what about the hoses, seals and grease you don't want
dissolved. They are made of petroleum too. For me Simple Green
and a brush works best. Won't harm your seal, hoses, paint, vinyl
seat cover etc and degreases pretty good too. It's biodegradable
and won't hurt the ground water over time. Something us hill folk
who still use a well are acutely aware of. Just my opinion for what
it's worth.
Dano
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2023 Kubota Z252KH-54 Zero Turn Mower (A63118)
2023 Kubota...
2019 F-550 Bucket Truck (A63118)
2019 F-550 Bucket...
2019 JOHN DEERE 333G SKID STEER (A64279)
2019 JOHN DEERE...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
