Landpride RCR1872 Slip Clutch Disks Help!
   / Landpride RCR1872 Slip Clutch Disks Help! #1
wirlybird
Gold Member
Oklahoma
John Deere 3038 E, John Deere 3032E, John Deere 756, John Deere X585, John Deere 332
Just picked up a used 1872 cutter and I need the disks for the slip clutch. The cutter is using PTO shaft 826-656C and disk part number 180.015.019 (comer)
I found them at Messicks for $50+ anyone have a place to get these at a better price? Every dollar saved helps!
I am looking but so far no real luck.
Maybe a cross reference?
Thanks!
Thanks, I thought I had looked at them and seen $62 but I must have messed up!
   / Landpride RCR1872 Slip Clutch Disks Help! #5
Was just going to order from them until I found they wanted $25 to ship the two disks.
The disks are 5.5 inches in diameter and an 1/8 inch thick.
Sorry did not go that far to find out. Shipping can really tick me off...
No worries! They had a good price, compared to others, but crazy shipping ... AND you can get free shipping if you spend $1000!
I decided to look for disks by size and found a couple at Quality Farm Supply that are the correct sizes for $6.50 each and $15 shipping.
They might be slightly thicker, I'll need to check, but that is not a big deal. Mine are probably worn anyway.
Theirs are 0.12 inch thick and mine measures 0.118. It's just going to be used on a 60 or 72 inch brush hog so as long as it fits ok I think it will be fine.
At $6.50 each I can burn up a few!
   / Landpride RCR1872 Slip Clutch Disks Help! #7
What were the part numbers? It would be great if you could post them as then anyone else looking for the 826-656C slip clutch discs will know what to order.
Thanks!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
26120 (A56859)
26120 (A56859)
2024 CATERPILLAR 259D3 SKID STEER (A60429)
2024 CATERPILLAR...
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
