Fergie's in ICU
/ Fergie's in ICU #41
I've seen a few of these over the years. They were all nasty.
Friend of mine bought an XK-150 Jaguar, it developed a slight rod knock so his "fix" was to turn the radio up louder. Rod came out the side of the block.
Saw a Plymouth slant six that the owner ran without oil - kablooie - swapped the engine, I still have that conrod someplace, looks like a pretzel.
10HP generator - after the big bang, you could look through the block from one side out the other. About the only thing still good was the valve cover.
I think they ought to be putting in a new engine under warranty. That will be less expensive to them and more reliable for you than trying to salvage whatever is still good in the blown engine. They'll spend weeks cleaning all the shrapnel out and there's no guarantee they'll get it all.
Squeeze them to make sure they extend your warranty to cover the new engine!
Best Regards,
Mike/Florida
/ Fergie's in ICU #42
Picked up a slant 6 with a broken rod and frozen motor.
The state had a program where they retired older cars and paid $500
The catch is the car had to be currently registered, start and move forward and back.
I took my torch and burned through the rod…
Started the car and drove it into the yard and it passed the start, forward and back.
Got my check in the mail.
/ Fergie's in ICU
My point was they seem to be the same engine, adjusted differently ... From the sales brochure ...
But looking at the owners manual, it seems to have a slightly different number ...
But in the service manual under the engine category, it makes no distinction about them being different ... ?
I agree, it's the same basic engine. There may be some tuning differences in the injector pump to "detune it".
BTW, the trannies have slightly different gearing. I assume that is to let the engine run a tad faster at the PTO speed(s).
/ Fergie's in ICU #46
Curious what engine RPM you need to run to get PTO 540 RPM?
I'm just a tad under 2900, which is past your redline ...
/ Fergie's in ICU
The rear PTO (540 rpm) is at 2532 rpm on mine versus 2829 on yours.
The mid PTO (2000 rpm although the service manual [page 1-29] incorrectly says 540 for this too) is at 2476 rpm on mine versus 2947 on yours.
I have never used either PTO.
/ Fergie's in ICU #48
quote from I do cars presenter: "...after market inspection port"... when refering to holes in the block.
I to have had a big end break off and exit. Big end bolts failed. Picked up a piece of the block and rammed it between the piston and cylinder and stopped in 3/4 of a revolution.
/ Fergie's in ICU #49
Any more info from the dealer who's tearing the engine down? They actually might not spend any time tearing it down, and just replace the whole thing to save labor costs. Then ship the blow engine back to the factory for inspection and anaysis.
/ Fergie's in ICU #50
I sure wouldn't, if it was my dealership. Beside simple curiosity about the failure mode, there is no incentive to spend time paying your technician to disassemble it. Nothing reusable inside that deceased motor. But Massey might not even allow the dealer to tear it down.
/ Fergie's in ICU
No word yet, but I'll contact them later today.
I think they will have to at least remove the oil pan to look at the debris and try to find a cause. Might send out the oil for analysis too. They will have to determine a cause to see if it is covered by warranty or not.
/ Fergie's in ICU #52
The only way I could see them denying a claim, is if they found no oil in it!
Otherwise ... It's not "operator/owner" error, but they built a faulty engine that acquired an unauthorized premature disassembly!
/ Fergie's in ICU #53
I had a gearbox come apart on my batwing that was replaced under warrantee. The question that I was asked over and over again was if there was any oil in it. Fortunately, I took a picture of it right after it happened and you can see all the oil that came out of it when it came apart.
That picture was all I needed to get the new gearbox replaced for free under warrantee.
Hopefully the same will happen with this engine and Massey.
/ Fergie's in ICU #54
Sorry to hear your Fergie’s laid up. Always tough when the old workhorse is down. What’s the issue—engine, hydraulics, or something electrical? A bit more detail might help folks here point you in the right direction. Hope it’s nothing too serious and she’s back out in the field soon.
/ Fergie's in ICU #55
first post shows picture of hole in block...
/ Fergie's in ICU #57
/ Fergie's in ICU
I'd like to give you a nice update on this but we're not getting anywhere with this so far. The mechanic "started diagnosing" it last Tuesday and filed a claim with "the warranty people" but has not removed the engine. The service lady thinks he may have "poked a camera in it" but isn't sure.
/ Fergie's in ICU #60
may have poked camera in to take pic of rod ends to send to warranty dept. prob can't touch it much until they get the go ahead.
2007 Mack CV713 Granite Truck, VIN # 1M2AG11C37M043941 (A65563)
2007 Mack CV713...
2025 JMR Stump Bucket Skid Steer Attachment (A64553)
2025 JMR Stump...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2007 International 4300 S/A Dump Truck (A64556)
2007 International...
Lincoln Electric Power Mig Welder (A65579)
Lincoln Electric...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
