JD 2520 repair after ending up in the water.
/ JD 2520 repair after ending up in the water. #1
gertjand
Netherlands
JD 2520
Hi My JD 2520 compact ended up in te water :( so rods are bend due water in the engine and water not very compressible :(.
Engine is 3TNV82A BMJK but it's really tough to find parts. I can find JD parts which are hard to get by in the Netherlangs but I would think Yanmar parts should fit as well. Drawings of all the 3TNV82A variants are similar but its impossible to find the BMJK version in Yanmar parts catalogs.
Yanmar partJD part
Rod719810-23100 ( 237)AM881983 337.03
Gaskets719823-92950 (268)MIA880852
Spings119802-22500 (57)AM881986 (125)
Cam Shaft119802-14580 (334)AM881983 (680)
E.G.
so https://www.dutchengineparts.nl/ring-set-piston-119802-22500.html
vs
Any suggestions?
/ JD 2520 repair after ending up in the water. #2
Have you attempted Googling part #s. I would have thought Yanmar engine parts would be fairly easy to locate.https://www.amazon.com/719810-23100-Connecting-Yanmar-3TNE78-3TNE78A/dp/B08MTFCDTW
Thx, I tried but now I'm sort of cross referencing it via another model.
Yanma partJD part
Rod719810-23100 ( 237)AM881983 (337.03)
Gaskets719823-92950 (268)MIA880852 (468.07)
Crank shaft seal119934-01800M805278
1445 DIESEL FRONT MOWER -PC10345 shares the same engine but you can look that one up with Yanmar parts.
just ordered the parts, wait and see...
thx again.
/ JD 2520 repair after ending up in the water. #4
Yanmar partJD part
E.G.
vs
Any suggestions?
I'm speculating here but, what does the 'BMJK' even mean? It might just mean that engine mates to certain mounts, certain flywheels, etc while the internal parts could be identical.
I think so too. It's probably just variations in coolingsystem, exaustsystem etc. But it seems that there were internal variations as well. Engine CC's are not always the same in the different 3TNV82A models.
/ JD 2520 repair after ending up in the water. #6
Yanma partJD part
thx again.
That engine IS a Yanmar. AFAIK, John Deere doesn't make a single part in that engine. I could be wrong but I don't think so. Not a JD kind of guy so don't take my word for it.
/ JD 2520 repair after ending up in the water. #7
umkay. If you say so. But it looks to me like the '82' in the part number indicates it's an 82 cubic inch engine. OTOH, it could mean it's got a bore of 82mm.
Good luck
/ JD 2520 repair after ending up in the water. #8
It’s on another forum someone is rebuilding a similar engine. In his case he bought it knowing it had problems and had a badly seized crank. He is having problems getting the correct crank. The used one he got went in but the pistons ended up sticking up above the deck a little bit. My point is there are some variations on these engines. I’m pretty sure it’s an all Yanmar engine also.
/ JD 2520 repair after ending up in the water. #11
Tractordata shows JD compact 2520 has a Yanmar 81.2 cid engine & you're correct JD outsourced that engine & all it's parts from Yanmar.
/ JD 2520 repair after ending up in the water. #12
Yanmar partJD part
E.G.
so RING SET, PISTON
vs
Any suggestions?
thats rough when they get hydro locked. Ebay's an option
/ JD 2520 repair after ending up in the water. #13
Yanmar partJD part
E.G.
vs
Any suggestions?
Be sure to triple check all measurements on Yanmar parts you may cross reference. While I’m not certain about the engine on a JD 2520, I do know that the earlier 50’s tractors were build by Yanmar to JD specs and lots of Yanmar parts were not the same as the Yanmar JD counterparts.
Best of luck on your repairs!
/ JD 2520 repair after ending up in the water. #14
Yanmar partJD part
E.G.
vs
Any suggestions?
I used to have a John Deere 950 tractor with a Yanmar engine and when I couldn't get parts from the local dealer quickly enough, I bought Yanmar parts online, they worked fine.
/ JD 2520 repair after ending up in the water. #15
Back in the day, I worked at a shop that repaired crankshafts of many types. Big ones, medium sized ones and HUGE ones (for Metal Stamping machines).
The problem will be if the crank is bent. If it is, I don't know if anything can be done. If it isn't, it shouldn't be a problem to weld it up and re-grind it to specs. I operated the grinder, not the welder so there's that.
The shop would sometimes even chrome the journals. Industrial Chrome, not Bright Chrome. That was fun to grind.
I had an older Deere SCUT one time and the parts were usually available but you didn't want to pay the price for them.
Otherwise, look in a junkyard. Good luck there. The parts are in such demand, they get snapped up before they even hit the market. But maybe you'll get lucky. Don't know until you try.
/ JD 2520 repair after ending up in the water. #16
Back when I had a Yanmar tractor, I found that Marine houses were the easiest and most reliable places to get Yanmar diesel parts, since they use so many of them in boats.
/ JD 2520 repair after ending up in the water. #17
The Yanmar diesel is often the best and most reliable part on a Deere CUT
SWICT 60" SKID STEER BUCKET (A60430)
SWICT 60" SKID...
(1) 300 GALLON POLY TOTE W/CAGE (A60432)
(1) 300 GALLON...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
2008 KOMATSU D51PX-22 CRAWLER DOZER (A60429)
2008 KOMATSU...
Kubota M125X (A60462)
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
