Mixing concrete - "Mud mixer" alternative. Steele mixer
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #81
I grabbed one from https://steelemixer.com/ a few months ago because I was tired of dealing with my old barrel mixer. It’s way easier to load and clean, and I can mix small batches without wasting materials. I mostly use it for fence post work and small slabs, and it's held up great so far. Doesn't strain my back like lugging buckets used to do.
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #82
I saw a recent video on the Tube, and they tested Mudmixer (with extension hopper), vs the old 110v HF mixer. It look them 3.5 hrs to mix 1 yard, vs 5 hours with the HF. It did put some perspective; IE, the mudmixer is Faster, and by a good amount, but still not suited to mix 3+ yards per day. Watching some of the ads, and videos, they kinda make it look like its capable of mixing, say, a yard per hour.
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #83
The problem with that comparison is that when you're mixing bags all the work is in moving the bags.
I have the Kobalt mixer from Lowes (https://www.lowes.com/pd/Kobalt-4-cu-ft-0-5-HP-Cement-Mixer/3591096 ) . The stated maximum capacity is 240 lbs, but I find it works better with 180lbs, three 60lb bags. A yard is about 60 bags, or 20 batches. It can mix a batch in five minutes, so 100 minutes or 1:40 to do a yard.
But to achieve that I'd have to have someone feeding bags and taking the mixed concrete away while I ran the mixer.
   / Mixing concrete - "Mud mixer" alternative. Steele mixer #84
Yeah, but in the video, 1 guy ran both solo. He did mention, he could have done the Mudmixer faster, if it wasnt for needed to screed and edge.
But, I do think it was a pretty good representation of what a single guy can do with it.
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2009 Ford F-150 Ext. Cab Pickup Truck (A55973)
2009 Ford F-150...
LOT: (3) Adjustable Steel Racking Sections, 9' W x 24" D x 56" H (CONTENTS NOT INCLUDED - DELAYED (A59076)
LOT: (3)...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
