What have you done to your Branson today?
/ What have you done to your Branson today? #1,781
My new blades...
They have 3 mows on them now, around 30 acres. They still have most of the paint left on them. Sigh. Probably going to order another set. Last set lasted 8 years.
Oh, and here's my new front chain guard...
Yeah, it's coming off.
/ What have you done to your Branson today? #1,782
Yup. That's why people over here stopped bothering with blades and went with chains like 40+ years ago. These days, unless they're strictly mowing pastures, they just stick to the chains.
I like the chain guard. Nice and tight between each section. IMO, it's about the only guard that actually works and lasts. I've seen some mowers with those sections so spaced apart that might as well just not have any guards.
/ What have you done to your Branson today? #1,783
Glad you got it fixed, thats a lot of work just to repair one little wire...
/ What have you done to your Branson today? #1,786
Been working on expanding my water storage for irrigation purposes. Right now, I have just a single 1000L IBC, so I've been building a platform that can hold 3 IBCs.
This structure is made out of pre-stressed concrete beams and concrete blocks, so the Branson has been very handy moving all of these materials to place.
Basically, use the bucket to move the mixed concrete into place, leave the bucket there and come grab the forks to move the beams and blocks. I don't even lock the quick attach most of the times, since I'm always swapping attachments.
While I don't like doing heavy lifting with a tractor, I did have to this time. Lifted a big bag with 1400 lbs of sand (I weighted it) to max height, which along with the weight of forks (about 300 lbs) was the max it could lift.
I was very happy to see that the 1700 lbs lifting capacity I calculated when designing the loader was pretty much spot on in "real world". I did built based on the aftermarket loaders we have here in Portugal. Regardless of the brand, they all cap out at the same capacity based on the weight and size of tractor.
Then, during the weekend, the long waited rain finally came. So it was time to mow all of the old vegetables that weren't producing anymore, then plow the soil and till a new vegetable plot.
This gave me another change to use and learn about the plow some more. Still a work in progress, but doing well.
/ What have you done to your Branson today? #1,787
Started the seasonal change out from summer mowing and yardwork to winter snow removal. For me, that entails pulling most of it out of the shed and rearranging it so the summer equipment is behind the snow equipment. Only took a few pictures of equipment dragged out of the shed.
Very handy to have a set of pallet forks to move everything around without having to hitch and unhitch from the 3 pt.
/ What have you done to your Branson today? #1,790
Actual hours Don’t remember if purchased fall of 2012 or 2013
LOAD OUT AND SHIPPING (A61165)
LOAD OUT AND...
2009 FORD F-150 (A60736)
2009 FORD F-150...
2014 New Holland B95C (A60462)
2014 New Holland...
2015 Freightliner Coronado 122SD T/A Day Cab Truck Tractor (A60352)
2015 Freightliner...
2020 VOLVO VNL760 6X4 T/ A SLEEPER TRUCK TRACTOR (A59906)
2020 VOLVO VNL760...
207280 (A52708)
207280 (A52708)
