Fixed - Grease zerk replacement.
/ Fixed - Grease zerk replacement. #1
BufordBoone
Tuscaloosa, Al
Kubota L5740 & M7060
Got a grease zerk that won't take grease. I've got one of the tools that you put oil in and tap the piston to clean the zerk. Although it has worked on others, it has not on this one.
I've been unable to unscrew it using wrenches and, next a pair of vice grips.
It is the zerk to grease the quick attach piston for the bucket/grapple, etc.
Anyone think a bit of heat might help?
Any other ideas?
Thanks.
/ Fixed - Grease zerk replacement. #2
Are you able to slide the piston partly out and pump grease in to blow the blockage out, then push the piston back in?
Some times a pin on the loader will refuse to take grease and this method is very effective for me.
I don't think I explained the part correctly. What I called the "quick attach piston" is that pin which has an angled base. It is moved up and down when you raise and lower the levers to connect a bucket or grapple.
I've tried manually putting grease on it and working it up and down. Didn't clear the blockage.
Blockage is bad enough that my DeWalt grease gun ends up spitting grease out of its check valve.
I tried the oil/piston cleaner (Grease Buster type), a bunch of times. No luck.
I figured I needed to replace the zerk. It has flats on it for a wrench. Couldn't find one that would work in either metric or SAE. Next tried some needle-nose vice grips. They won't turn it, either.
I'm left wondering if a bit of heat might help.
This is not an emergency. Manually rubbing grease on the pin will get me by till I figure this out.
Redman, are you recommending disconnecting the lever so that I can get to the inside of the system?
Thanks for the help/suggestions.
Is it possible it's a drive in zerk..??
Now there's something I didn't think about. Hell, I didn't even know there was such a thing.
Since I can't turn it, I expect it will be very difficult to pull out.
Think I'll ask at my dealer.
Thanks!
/ Fixed - Grease zerk replacement. #6
It s a judgement call. If it’s imperative then do what ever it takes. That’s what you are going to have to do in the end. No short cuts when it comes to lubricants
/ Fixed - Grease zerk replacement. #7
/ Fixed - Grease zerk replacement. #9
Is there a bushing for that pin. Reason I ask is I have seen bushings get dry and gall to the pin enough to rotate in the housing. When this happens the grease hole in the bushing will no longer be aligned with the zerk and putting grease into the joint by the zerk will be impossible.
/ Fixed - Grease zerk replacement. #10
I've had a few of those. In each case, I pulled the pin and removed the rock-hard grease from the passages in the pin. The zerk usually works fine, it's the dried grease that blocks things.
Good info. Thanks!
/ Fixed - Grease zerk replacement. #12
Had a grease fitting on my tractor that wouldn’t take grease and I tried a bunch of times with different grease guns no luck. About six months later I tried again and it took grease very easilly, I have no idea why that happened but now I’m thankful I didn’t attempt to replace the fitting because access would have been pretty difficult.
/ Fixed - Grease zerk replacement. #14
Quote
OP, post 10, Oldtrix, this is what I meant, just without removeing the pin entirely. Most likely only the grease at the pin end of the grease gallery is a solid plug.
OP could you please post a photo of the pin so we can see exactly what we are dealing with?
/ Fixed - Grease zerk replacement. #15
Thanks!
Every drive-in zerk i've ever replaced came out easily with a 5/16" wrench. The screw-ins in my equipment are all 5/16 or 3/8" hex. I keep an adequate supply of zerks, straight, 90°,45° and a few 30°. If one gives me trouble, it's soon gone.
I even have 4 new spring-pressure grease reservoirs JIC; you fill them with a grease gun and the spring applies constant pressure on said grease to keep the bushing, etc, constantly lubed.
/ Fixed - Grease zerk replacement. #16
Maybe accelerated wear?
/ Fixed - Grease zerk replacement. #17
I’ve had some difficult ones on antique cars and machines…
One was a bear so I used a hammer driven greaser with mixture of kerosene and grease over several days with heat on the bushings… it worked.
I think the kerosene was enough of a solvent to slowly work.
/ Fixed - Grease zerk replacement. #18
Rotating to different positions has also worked…
There was an old estate drive gate not opened in years and it wouldn’t take grease… heat and lifting the gate ever so slightly with floor jack did the trick…
The 16’ gate had enough leverage to do some real damage if simply forced…
Gate company had a 250 minimum and thought maybe a $500 hinge replacement possible…
Fixed!
I took the pin out and used a wire coming in from the back side to clean the area out. A couple times of doing that and using the piston grease zerk cleaner and it finally broke loose.
Below is a photo of the zerk. Taking the pin out was not too difficult. Has a cross pin holding the big pin to the linkage. A cotter pin and it was out.
I cleaned everything up and reassembled and all is good now.
Thanks, everyone.
/ Fixed - Grease zerk replacement. #20
BufordBoone,
That is a rough place for a grease fitting due to the bucket being dipped into all the worst piles of dirt, or backdragged causing dirt to pile up in that area. I tend to keep it over lubricated just for those reasons.
David from jax
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
UNUSED RAYTREE RMSC78-78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
Gravely 260Z 60in. Zero Turn Commercial Mower (A61567)
Gravely 260Z 60in...
UNUSED WOLVERINE SWDB-11-84W HYD DOZER BLADE (A62131)
UNUSED WOLVERINE...
2014 Lincoln MKC SUV (A61569)
2014 Lincoln MKC...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
