Pond rim options
/ Pond rim options #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Well, we got the hole dug for the pond and all the rocks raked off of the bottom and the sides sloped. We are gonna buy some sand to put on the bottom before the liner goes down. I don't even know which liner I'm gonna use. When the liner goes in the hole it will come up the sides and lay on the surface. Rocks or pavers or flags will be placed on the liner to keep it in place. I don't know what to use and would love some advice and suggestions. The pond is about 3 feet deep and about 15 feet long and 8 feet wide. It is sorta kidney shaped. It is also already getting expensive and I would like to minimize costs. Like all of us.
Thanks All,
Eric
/ Pond rim options #2
Just be sure that whatever you use doesn't have sharp edges that can cut the liner material.
/ Pond rim options #3
I'd start with sandbags until the liner and ground settles once the little pond is full. Much easier to adjust and visualize what you want.
/ Pond rim options #4
I have heard people of people sometimes putting carpet down under the EPDM to ensure that the liner does not get punctured.
/ Pond rim options #5
We’ve built 4 different ones between the last couple of houses. We don’t use sand just line the hole with old carpet. tuck the liner in about a foot or so all around the outside and cover with flat stone. Here’s a couple of pictures from our current pond, it’s about 650 gallon.
This what it looks like 8 yrs later We’ve moved the waterfall a couple times and let the gardens grow up around it
/ Pond rim options
Thanks folks for your replies, especially fishin coyote. It looks like I'm gonna use something called RPE, which stands for Reinforced Poly Ethylene for the liner. I'm also gonna have 3 inches of sand in the bottom of the pond and at least two inches of sand around the perimeter. I will be using flags and natural stone from our place to line the perimeter. Flagstone is kinda expensive around here so we will be shopping around and probably go off island for the flags. I would rather avoid concrete pavers. They look crappy. Dunno yet if we will have fish. My wife really wants a pond. I would rather buy the adjacent 5 acres because it has a year 'round creek which would obviate filling a pond with my well and would constantly feed a pond with frog eggs and then frogs would hang out and maybe one or two of the rare turtles native to Whidbey Island would hang out too.
Eric
/ Pond rim options #7
View attachment 3987885This what it looks like 8 yrs later We’ve moved the waterfall a couple times and let the gardens grow up around it
nice job...lots of aquatic activity. are those lotus plants in one pic? in contained areas like yours, they add interest. in larger harder to control ponds, they can be very invasive. regards
/ Pond rim options #8
Eric
We have a year round stream. By simply widening the stream in three places it now forms a series of three small intercnnected ponds.
We originally had a single larger pond made by digging a 10 foot deep hole a few feet away from the stream and let seepage through the porous rocky soil between the two filll the pond.
The problem with any pond is that they eventually fill in with leaves and such. It helps to have some sort of flow through, and the ability to clean out the sludge every few years.
rScotty
/ Pond rim options #9
big bubba, Yes it’s a oriental lotus. We’ve had it for 15+ years. It’s in a good sized pot. I’d never plant one without a pot or in a large pond, to easy for them to grow out of control. We have a local lake that is just polluted with american lotus it covers acres water ruining boating and most fishing opportunities.
/ Pond rim options
I roughly measured the pond today. 27 by 15 by 4 feet deep. That works out to 12,000 some gallons. It will actually be less. I'm gonna need a big pump to exchange all the water in one hour. Looks like I'm gonna be running a 2 hp pump 24-7. That's gonna be expensive. I wonder if the whole pond volume really needs exchanging once an hour. Gotta talk to some folks.
Eric
/ Pond rim options #11
The liner for my 1 acre pond cost like $20K in 2014. Wouldn't want to re-do the project this day and age...
/ Pond rim options #12
Eric, Are you going to have fish, waterfall or any other features such as fountains, spitters etc.?
If you’re not going to have fish then you definitely don’t need to exchange all of the water every hour.
If you’re planning on fish especially Koi or Goldfish then you’re going to want the every hour exchange along with some sort of filter system. I’ve kept fish without any filter but you have to keep the amount of fish to a minimum.
/ Pond rim options
We are gonna have a waterfall at the very least. Fish too but not sure which kinda fish.
Eric
/ Pond rim options #14
wise move on pots. good to see aquatic vegetation, it also filters, etc the water. my 4 ponds are large & i keep Amur carp to keep things in control. keep up the good work
/ Pond rim options #15
Eric
Sounds like a great project. I'm glad now that I connected to the creek ifor our ponds nstead of using a liner. We didn't realize it at the time, but local moose, elkm and bears would have just poked holes in any soft liner we could afford. But they are all fun to watch.
If you put in some fish, you will also get to see how many critters like a fish dinner. Mink, great blue herons, otters and kingfishers can clean out a shallow pond in a morning.
2022 John Deere 520M Loader (A63116)
2022 John Deere...
KUBOTA KX057-4 EXCAVATOR (A62129)
KUBOTA KX057-4...
(INOP) 2009 FORD F-250 XLT SUPER DUTY CREW CAB TRU (A62130)
(INOP) 2009 FORD...
2021 Chevrolet Express 2500 Cargo Van (A61568)
2021 Chevrolet...
UNUSED RAYTREE RMBD72 - 72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 1HTMMAAL0DH414751 (A61165)
INOP/NON-RUNNING...
