Old Bush Hog leaking
/ Old Bush Hog leaking #1
BruceMyers48
kubota 3901
The gearbox on a 20 year old Bush Hog is leaking, can I fill with grease, what type should I use and should I drain old oil out first?
Thanks in advance
/ Old Bush Hog leaking #5
/ Old Bush Hog leaking #7
Thanks in advance
You don't need to drain whatever oil is left in the gearbox, just pump a bunch of grease in it and check it yearly when you do your Spring maintenance on the slip clutch, PTO shaft , etc, it will be good for the life of the gearbox.
/ Old Bush Hog leaking #10
This is from Tractor Supply and works well. I don't think the regular grease you use in a greasegun works because it gets pushed away from the gears and hardens, leaving the gears with no lube.
David from Jax
/ Old Bush Hog leaking #11
I have an old rotary cutter that I have been using grease in the gear box for MANY years, and it gets used hard.
I just buy cheeep tubes of grease and put it in a half tube at a time, it works perfectly.
SR
/ Old Bush Hog leaking #12
Thanks in advance
I use 00 picker grease. It is not pourable but I remove the fill plugs and pump it in with a grease gun. It becomes thin enough with a little heat to fill all the nooks and cranny’s but thick enough not to run right back out of a bad seal.
/ Old Bush Hog leaking #13
Thanks in advance
I read on here several months ago a solution and it Worked for me: replace gear box oil with John Deere Corn Head Grease [Amazon -2 pack] I have a Hardee Williams 6' that would go through 90w. Drained it as best I and put in 2 tubes
which is still there, cut grass all summer ...I just bought two more tubes - just incase, I can see no loss since put it in
/ Old Bush Hog leaking #15
Put a quart of Lucas oil additive, it’s thick like the old STP and will slow or stop the leaking rig to get by.
/ Old Bush Hog leaking #16
Thanks in advance
I put corn head grease in my old Rebel Bush hog and it’s not leaked since
/ Old Bush Hog leaking #17
David from Jax
Will second the Super S 00. I've used it for years with a bad bottom seal with no issues. The bottle works well to just squeeze into the vent hole.
/ Old Bush Hog leaking #18
This works well. Drain and fill
Lucas Hub Oil.
2018 International WorkStar 7400 T/A Lely 4,500 Gallon Septic Wet Vacuum Truck (A61568)
2018 International...
Freightliner Tender Truck - Adams Tender (A63118)
Freightliner...
2006 PACE AMERICAN CS714TA2 14' CARGO TRAILER (A62130)
2006 PACE AMERICAN...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
PALLET OF SITE FENCE STABILIZERS (A62131)
PALLET OF SITE...
