Kubota LX2620HSD with 5' rear snow blower?
   / Kubota LX2620HSD with 5' rear snow blower? #1
alexinPA
NE PA (Lackawaxen)
Kubota B7800
Anybody used it? I understand pto hp is low for 5 footer, but still.. I got 1/4 mi hilly driveway. Will it work?
   / Kubota LX2620HSD with 5' rear snow blower? #2
Depends on the type of snow you get. Wet heavy slush a full swath will be slow going, light fluffy snow no problem.
I have a 52 or 54” on my 2400H which is similar power and with the HST tranny it works just fine since can vary speed as needed. Might need a little weight on front to help steer when blower is raised.
   / Kubota LX2620HSD with 5' rear snow blower? #3
I think you'd be fine with a 5 ' blower on that machine. With an HST you can get nice and slow if necessary.
I ran a 6' blower for many years on my previous 27hp (pto) machine without issue.
   / Kubota LX2620HSD with 5' rear snow blower? #4
No problem. I live in Northern Ontario and I've never had a snow that bogged my B2620 down. Full width and height of blower. Mine is only the 51 inch but I wish I had bought wider because it would handle it no problem.
   / Kubota LX2620HSD with 5' rear snow blower? #5
You might want to check out the Bercomac front mount units, My old neck would never move again if I spent any length of time twisting around to drive backwards to run a rear mount blower. Bercomac has two versions. One has it's own motor for power and mounts on a SSQA Front end loader. The other has it own subframe mount, and is powered by a mid mount PTO.
   / Kubota LX2620HSD with 5' rear snow blower? #6
The problem with a blower in alot of the northeast is you will get wet sloppy snow and that type of snow just dosnt blow well. What's your plan B for those storms?
I have owned a 6' blower for my tractor for about 4yrs here in NY and have yet to even blow snow with it. We mostly get smaller storms or really wet snow. Gone are the years of a decent 1'-2' storm. I now mostly just pack the snow on my gravel driveway. Usualy it's gone in a few days.
   / Kubota LX2620HSD with 5' rear snow blower? #7
I don't know about OP, but in my case I'd just use the loader. Blow what I can and move what I have to, it certainly beats my current setup- a loader with a box blade.
How steep is the kill, OP?
It's steep and twisty. I use rear blade most of the time. But when we get good amount of snow I run out of space, driveway gets too narrow. That's why snow blower gets handy
   / Kubota LX2620HSD with 5' rear snow blower? #9
99% of the time I don't need my blower, but it does come in handy for the infrequent blizzard or back to back snows that narrow my driveways down.
   / Kubota LX2620HSD with 5' rear snow blower? #10
To answer the original question, yes it will work. I have a 6 footer on the back of my 19 pto horse tractor and it moves it just fine. It is wonderful touching it once and having it gone, versus plowing and running out of room. Having the hydrostatic drive helps, as you can adjust your speed according to the snowfall type and amount.
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2013 Nissan Rouge SUV (A59231)
2013 Nissan Rouge...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
