What did you buy this week?
/ What did you buy this week? #2,461
Glad you found replacements.
Ive had luck with stubborn gland nuts by heating the outside of the tube and hitting it around its circumference with a good sized brass hammer. Usually spraying a penetrant in between heating and hammering.
/ What did you buy this week? #2,462
I got this today. Vevor top link. Mine the pipe got damaged and I got tired of fooling with it. I'll keep mine for a spare. I removed that safety catch on it and didn't use hoses or banjo hardware because my hoses connected to it fine. $142 from Walmart online.
/ What did you buy this week? #2,463
Yes Glad Koyker still makes and sells OEM parts
Yep, I did the peening, and heating, and PB Blaster more than once, cheater tube on the large crescent and also pipe wrench. The only thing that I really had luck with to start them turning was an air hammer to get that first 1/4" of turn. Started by marking an alignment line so I could tell when things were finally starting to turn.
The Gland nuts Koyker uses for some reason are Aluminum... and they are definitely not as tough as steel units.
The other three were not easy but doable without major damage and turning into a 1/2 day nightmare.
Here is a picture of the Gland nut after removal from the cylinder, No damage to the rod, I knew things were likely to get rough so I wrapped the an old bicycle tire inner tube around the rod and taped it as well.
/ What did you buy this week? #2,464
Yes aluminum sucks. Hopefully you applied some never seize for the next time or next person.
/ What did you buy this week? #2,465
Darn straight. Plenty of anti-seize applied.
I alignment marked the other tractors FEL cylinders years ago on reassembly and went light on the gland nut torque Nothing has ever moved.
/ What did you buy this week? #2,466
Did you replace that gland nut?
/ What did you buy this week? #2,468
Id look into whether GA sold them without restrictions.
Whats a little smuggling between friends.
Yep Georgia is a no questions asked state regarding grass carp. (Sterilized) I ordered 20 a couple years ago through the local hardware store. 12” fish $10 each. The fish truck comes through a couple times a year for pickup in the store parking lot.
/ What did you buy this week? #2,469
Waiting to receive Gland nut and seal kits from AG parts Direct.
I did chuck the Gland nut up in the Lathe and cleaned it up quite a bit just in case, but will be installing the new parts when they arrive.
/ What did you buy this week? #2,475
Mini fridge for my son's Dorm room.
We have 3! Youngest was just in town with her husband picking up lots of her furniture we've been storing while they were in Oklahoma. They left a mini fridge because they already have two. ...
they multiply on their own!
/ What did you buy this week? #2,476
On Saturday I bought a Land Pride QH16 quick hitch and a Land Pride GS1560 grading scraper for my NH WM25. Today I bought 4 yards of recycled asphalt to start topdressing our driveway. Weight wise that is all my Big Tex 14TD dump trailer can haul in one trip. I could tell it was behind me.
/ What did you buy this week? #2,477
Since the girlfriend left I have purchased an electric can opener, block of knives, silverware set, egg steamer, floor steamer, and a Stihl cordless weed trimmer. I'm sure the list will get bigger as I discover nothing, where there used to be something. :rolleyes:
/ What did you buy this week? #2,478
ouch...
/ What did you buy this week? #2,479
Just got this assembled yesterday. Aerator/seeder. Those spurs are razor sharp. I am hoping to not have to disc/till up my food plots this year (or from here on out). Lets see how it works out.
Its almost time to seed clover winter peas, radishes oats etc in the plots.
Waiting for the next rain then I'm gonna seed stuff up....
Adams Under Truck Conveyor (A61307)
Adams Under Truck...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
500BBL WHEELED...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A60430)
UNUSED SET OF...
(APPROX.15) 5/8"-4'X8' OSB (A60432)
(APPROX.15)...
