KIOTI CK20 HST Transmission update
   / KIOTI CK20 HST Transmission update #1
Drivenhard
2003 Kioti CK20HST
Once I received all of the correct parts and the help of answered questions, I was able to finish assembling the Transmission on my tractor. While apart, I replaced the pump and main shafts, couplers, bearing and seals along with the o-rings. It was a big job for me. I put the tractor back together (3 sections). Yeah!!! Everything works. 🎯🎯🎯
   / KIOTI CK20 HST Transmission update #2
Sounds like a good job! Changing some things not completely gone while you have access to them. That’s the only way
   / KIOTI CK20 HST Transmission update #3
Great news.
How many hours on your CK20, and why did it fail?
   / KIOTI CK20 HST Transmission update #4
Hi, want to share any pics of you splitting that tractor and fixing the trans? I've got an '04 CK20H that just started leaking oil out of the trans, going to have to split it soon to fix. My tractor was in a fire and i think that's a part of why it's leaking, i fished some chunks of melted plastic out of the cavity under the trans, and looking up there with a scope i see more melted plastic. Worked great for a couple years after the fire and a simple refurb, but leaking now.
   / KIOTI CK20 HST Transmission update #5
Amazing the tractor still worked after the fire. Are you in the US?
I bought a new CK20H for a friend (RIP) back in 2006, and he let the hired help use it. So it was trashed, and eventually stopped working. I tried to buy it as-is to repair, but no dice.
Great tractor. I want to see inside pix, too.
   / KIOTI CK20 HST Transmission update #6
I'm in Oregon. Ours has none of the factory wiring or dash, but it's a mechanical diesel and needs very few circuits to run, charge the battery and do it's job. We use the loader for a hundred things and a 3 point mower and 3 point grader, we have bigger machinery but this little tractor is so handy it gets used all the time.
   / KIOTI CK20 HST Transmission update #7
I'm like dfkrug & others - would very much like to see inside pictures and some detailed walks/talk through disassembly/re-assembly.
2015 FORD F550 XLT SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XLT...
JOHN DEERE 2750 TRACTOR (A54756)
JOHN DEERE 2750...
UNUSED (2) 7000# DROP AXLES W/ BRAKES (A54756)
UNUSED (2) 7000#...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
UNUSED LANDHONOR LDH-FPR36 - 36" FIRE PIT RING (A54757)
UNUSED LANDHONOR...
UNUSED 4.5X2X2M GREENHOUSE (A54757)
UNUSED 4.5X2X2M...
