BX 2230 3pt hitch
/ BX 2230 3pt hitch #1
cmyoung2
North west NC mountains
BCS 850, Kubota BX2230 w/FEL, mid mount mower, 41" tiller Kubota L3600 w/4-1FEL, Farmi winch
Is it possible/practical to keep the 3pt hitch in the up position while using the mid mount mower? I can keep the mower deck up while using the 3pt, can't figure out how to go the other way. The arms tend to dig in when I back up on unlevel ground.
/ BX 2230 3pt hitch #2
use rope or chain to hoist the 3-point up to the top link.....maybe
/ BX 2230 3pt hitch #3
I had a BX 2350 and the 3 point was setup to pin up. It seems like there were some eyelets for it but it’s been several years ago I traded it so I don’t remember the details.
/ BX 2230 3pt hitch #4
The three point lowers by gravity so any method to hold it up should work. You may also try slowing the lowering speed to zero by adjusting the valve by your feet.
/ BX 2230 3pt hitch #5
You could undo the arms and pin/tie them up, but the rockershaft still has to move in order for the deck to go down, unless you just limit the 3pt to keep the arms off the ground but allow the deck to set on the height adjuster.
/ BX 2230 3pt hitch #6
Mist
Most 3ph’s use gravity/weight for their down force. Double check yours by hold an non implement attached arm up and operate the lower lever. Once you know for certain there is no hydraulic down force on your lift arns, get a piece of chain or strap or whatever and secure the arms (without implement) in the up position (near top but not all the way, some slack will make removing a chain much easier). A piece of chain around the top link pin and around either lift arm and hooked to itself will work.
/ BX 2230 3pt hitch #7
I am trying to figure out why your arms are dragging on the ground. On my BX24 the arms are 9" above the ground at their lowest point. Pictures??
Doug in SW IA
/ BX 2230 3pt hitch #8
Doug in SW IA
I have a B2330 and my arms just barely clear the ground. On mine the arms are what actually lift the mower deck. Same on my B1550. So I had an old set of lift arms where I had made a three point hitch for my dad's Farmal C which I don"t use any more for a working tractor since I restored it. I cut one of the lift arms In two in the middle and put them on my Kubota. Now I don't have the problem of them digging into the ground. When I need the three point I just put the original arms on.
/ BX 2230 3pt hitch #9
I have a BX2230. It has a set of eyelets right below the rear tire fenders. Unpin the vertical arms from the lift arms and move them to the eyelets. My 3pt arms arm stationary as they are moving with a (rear implement)(oops). Jon
Should have typed: 3pt arms are stationary while the mid mount mower moves up and down.
/ BX 2230 3pt hitch #10
And I thought all BXs were pretty much the same. Learn something new everyday. Who would think there would be that much difference in 3 point arms.
Doug in SW IA
/ BX 2230 3pt hitch
civilian had the answer I think I was looking for. Tying the arms up does not work, mower does not lower unless the 3pt arms also lower. Moving the arms to the outside eyelets works, doesn't get them as high as I would like, but they shouldn't dig in now. My arms may be a little longer/lower because I also use the Pat's quick hitch.
Thanks for the replies
/ BX 2230 3pt hitch #12
Just unpin the lift links where they attach to the rockershaft, you can either attach them to the hole in the rops or just use a strap to hold them up.
The deck lift is actuate by the rockershaft.
I have my arms completely off when using the collector.
213087 (A64276)
213087 (A64276)
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
1987 GMC C7000 Fire Truck, VIN # 1GDM7D1G3HV526472 (A65563)
1987 GMC C7000...
New/Unused Quick Attach Backing/Mounting Plate (A65583)
New/Unused Quick...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A65579)
(1) HD 24ft Free...
