BX 2230 3pt hitch
   / BX 2230 3pt hitch
civilian had the answer I think I was looking for. Tying the arms up does not work, mower does not lower unless the 3pt arms also lower. Moving the arms to the outside eyelets works, doesn't get them as high as I would like, but they shouldn't dig in now. My arms may be a little longer/lower because I also use the Pat's quick hitch.
Thanks for the replies
   / BX 2230 3pt hitch #12
Just unpin the lift links where they attach to the rockershaft, you can either attach them to the hole in the rops or just use a strap to hold them up.
The deck lift is actuate by the rockershaft.
I have my arms completely off when using the collector.
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
JCB 270T T4 SKID STEER (A52705)
JCB 270T T4 SKID...
2013 UTILITY REEFER TRAILER (A54607)
2013 UTILITY...
UNUSED RAYTREE RHBC72 - 72" HYD BRUSH CUTTER (A54757)
UNUSED RAYTREE...
2016 FREIGHTLINER CASCADIA DAYCAB (A53843)
2016 FREIGHTLINER...
2013 FORD F450 XL SUPER DUTY BUCKET TRUCK (A51406)
2013 FORD F450 XL...
