F550?
/ F550? #1
Fields_mj
Central Indiana
Ford 1710, Kubota F2880, White FB16
I'm looking for a sanity check here. I'm starting to make plans to replace my 2000 F350. Its a 4wd crew cab with a long bed that I bought used from the original owner about 8 years ago. When I bought it, it was my daily driver, but I bought a used Camry 5 years ago. The cost of fuel paid for the car in just over a year. Truck has almost 270k on it, the engine and automatic transmission are fine, but the body is shot, and the frame isn't looking real good. I use it mainly for hunting, towing an 8500 lb travel trailer, and pulling a 10k equipment trailer with either a 5k tractor on it, or 8k-10k worth of logs for firewood. The Camry will likely need replaced first, and I'm thinking of something like a CRV or CX5 because they have a little more ground clearance and can easily tow a small harbor freight utility trailer which would make them more than adequate for my hunting needs and relegate the truck to purely a tow vehicle. In the production years I'm considering, the F250s, F350s, F450s, and F550s all cost about the same assuming they are in similar condition. I'm thinking a 4wd F550 dump truck would have enough payload capacity to haul the logs I'm currently hauling with my equipment trailer while also pulling the trailer with tractor which addresses the issue of not having a tractor to load with OR having to leave it behind when I drive home to unload.
To me, it seems like that a 550 would be the best option, but it also seems like jumping up to a 550 would have some draw backs to consider. Fuel milage is one that comes to mind. I'm currently putting less than 5k miles a year on my truck, so fuel milage wouldn't be a huge factor. Size/maneuverability would be another. Cab options factor into this to some degree. A standard cab is not an option. An extended cab is a possibility, but a 4 door with room for 4 grown men has some usefulness to me. As hard as it is to find a place to park a CC long bed, finding a place for a 550 dump truck is going to make it look like child's play. Using it to occasionally run to the grocery store would be out of the question. Running over to Walmart would be an option, but I'd need to park it at the back of the lot with the tractor trailers and tree service trucks. Depending on the wheel base and bed length, I might also have issues getting it through the woods in places where I CAN take my SRW truck now. There are a couple of turns in the lane that I can barely make currently. Then again, I am normally there to cut firewood, so those trees COULD be removed and used for heat. There's also storage. I currently park all our vehicles in the drive way because my 2 car garage was built (by the original owner of our house) with 6-1/2' wide garage doors. Goal is to replace the garage with a 2 story pole building that we can fit the vehicles in along with a camper (or enclosed trailer), but space would be a little tight because of how the property is laid out. Storing a longer, taller, wider truck might be out of the question. Best I might be able to do is have it under a car port. Then there's weight. Obviously tags/plates are going to be more expensive. Otherwise, I can't think of anywhere, including my yard, where the additional ~2,000 lbs of weight would be a concern.
Anything I'm not thinking of? Is it stupid for someone in my position to consider something like this? Before anyone tries to recommend replacing my F350 with a half ton, regardless of mfg, the answer is NO. I absolutely refuse to pull 10,000 lbs or more down the road with a half ton tow vehicle. If I were ONLY pulling my travel trailer, it MIGHT be a different discussion, but I'm not. I've always thought that was a stupid thing to try to do. I've since talked to several people who've spent their decades long careers dealing with trucks of all shapes and sizes and they confirmed my thoughts on the subject. Others may try it and succeed, but I will not push my luck.
Otherwise, what say ye internet?
Thanks,
Mark
/ F550? #2
New or used?
Personally I really want an F450 for towing. The big advantage of the F450 and up over the 350 and under is that it has the wide track front axle - turning radius is ridiculously small for a long bed crew cab, it's amazing. No other manufacturer has this feature. Better brakes, stronger axle, and dualies make it a better towing rig than the 350, though it has less capacity by the book. (since they have the same GCVWR, the extra weight of the heavier duty components eats into the calculated capacities). The HO 6.7 PSD and 10-speed is a dream to drive.
Insurance etc. is the same for the 450 as it is the 350 and under - that might not be the case with the 550 since it's in a different class. The 450 seems like the biggest "consumer" vehicle without being forced into "commercial". Not 100% sure on that but I would compare insurance (ease of getting it, and cost) as a first step.
/ F550? #3
I was going to mention the commercial vehicle insurance kicking in somewhere around there. At least something to be aware of and ask about. And potential for a CDL or similar license required.
/ F550? #4
Thanks,
Mark
As a former F-550 and current Ram-5500 owner, I don’t think you can really enjoy the 550/5500 trucks to their full capability without a CDL. Look no further than their GCWR to see what i mean.
F-550’s turn very tightly. That’s one of their best attributes. I had a F-350 and an F-550 at the same time, and I think the F-550 turned tighter.
Your vehicle registration fees will increase, and now you are looking at 6 tires instead of 4.
/ F550? #5
A wide front end F-550 is the sharpest turning truck on the road. They’ll way out turn a F-350 of the same wheelbase and I’m comparing coil spring 350s. If you go pre 05 to a leaf spring 350 the difference is even more drastic. A F-550 does get bad mileage. It’s getting 8-9 unloaded. The worst thing about the 550 is the ride quality absolutely sucks. If I’m not towing over 15k I’d just assume drive my 350 for the better ride quality. The F-550 has vastly better brakes over the 350.
/ F550? #6
My insurance company says they consider any truck without a regular pickup bed as commercial without any mention of GVW. My commercial insurance with the exception that I only haul products that I own is cheap enough. If I wanted to haul cargo for hire the insurance would be considerably more expensive. If the OPs trailer GVW is exactly 10,000 pounds he should be good to go without a CDL. If it was any more than that then he would need a CDL.
/ F550? #7
At least you can put a good load on the F-550 dump bed without a CDL. Dropping to a 350 dually doesn’t change the CDL part much. My 350 dually GVW is 14,000 which puts it solidly over 26k with my 14k trailer. My 1999 350 was 12,500 which is still over 26k with a 14k trailer.
/ F550? #8
Yeah, my truck’s insurance is really cheap.
I know that. I’m saying is that to fully enjoy the capability of a 550/5500, a CDL is needed.
I couldn’t use 1/2 of my 5500’s towing capability without a CDL
/ F550? #9
You actually could as long as you’re farming but that’s a different point. You can’t use even half my 3500s towing capacity either without going across the 26k mark so I don’t see that as being a big difference with either truck.
/ F550? #10
I’d also say a 5500 repairs would be more than a 3500, so there’s that and a 3500 would get considerably better fuel mileage. The 4.88 rears kill fuel mileage compared to 4.10’s
I have a CDL, as I use my 5500 and trailer for heavy towing outside of farming.
I have a 9 ton excavator I pull on my 19 ton GN which puts me way over CDL limit
/ F550? #11
I don't think anyone, anywhere has ever uttered THAT phrase!🤣
/ F550? #12
The F-550 literally throws cups out of the cup holder. My 3500 rides much nicer and my class 8 Volvo on air ride rides much better.
/ F550? #13
My F-350 & F-550 were horrible riding trucks. But the 550 turned really tight
/ F550? #14
Until the 550 gets at least a ton on the bed it rides like it’s on blocks. The 3500 is a much smoother ride.
/ F550? #15
Put farm plates on it and you don't need a CDL, at least in the PNW.
/ F550?
Honestly, I might look into that. About half the time I'd be using it would be for farm type work. I'm not opposed to getting a CDL, especially down the road. I turned 50 this year, and I might be in a position for early retirement in another 5 years or so. The F550 with a dump bed and a CDL could be an income stream at that point (plus a tax write off).
/ F550?
New or used?
Most definitely used. Something in the '99 to '10 range. '99-'02 I'd plan on keeping the 7.3 and probably put a chip in it. My stock 2000 7.3 has all the power I need, but with a lot more payload I can see myself wanting more ponies and TQ. If it came with a 6.0, it would just depend on what had been done to the engine as to whether it would get repowered or not. '07-'10 would absolutely get a repower on day 1. Its just a question of what Indiana will allow me to put in it. I need to do a little research there before buying anything. I've been told that Indiana is pretty lax in regards to emissions requirements, but I've never dug into it to know for certain. If repowering with a 5.9 isn't an option (both for regs and cost), I would likely limit my choices to the '99-'02 models.
My F350 rides WAY better than the '93 that I had, but my Camry rides better than both by a LONG shot :) Ride quality is irrelevant for this decision. Even with a really good turning radius, the truck would likely be too big to fit into almost any parking space. Short of using it to haul equipment and volunteers to a disaster site, I'd either be moving equipment or material, or on my way to get equipment or material.
On the subject of ride quality, would air bags help with that, and would those be an option for a 550 dump truck?
/ F550? #18
A year ago I was looking at F350 trucks and bigger to deal with the cattle at my other farm. I needed to tow equipment back and forth too. Then one day I got a call from a neighbor with an offer to buy my cows and rent my land. Accepting that offer changed everything for me. I realized that I really didn't like dealing with cows, or working on two different farms, and there was no need to buy a bigger truck and trailer.
My current needs involve less hauling, more trips to Lowes and the lumber yards. If I can avoid a trailer, I do so. I'm getting by with a F150 5.0 engine, but it's borderline and at 175,000 miles, it's just getting older.
Everyone I know says to avoid diesels if you don't need them. I've talked to enough people that have had issues with their exhaust systems, and what it cost to fix them, that I've decided on a gas engine.
My dream truck is a flat bed dually. I just like the look of them, and I think they would be ideal for hauling pallets of material. But I've also realized that it's not what I really need. My current thought is a F250 long bed with the 7.3 Godzilla engine. I know Ram has something comparable that I'll look at before buying, but either way, I think that's going to be what I end up getting.
/ F550?
I've been running a diesel for a little over 15 years now. The comments about maintenance largely apply to the '07 and later vehicles. That's tied directly to changes in emission standards that took effect in 2007 and resulted in most engines requiring DEF. The comment also extend to Fords 6.0L just because it was SO problematic. The heads on that engine were weak, and the studs were undersized. It had a couple of other issues as well, but blown head gaskets was the biggest issue. I've met people who spent more repairing head gaskets than they spent on the truck to begin with.
The 6.9 and 7.3 IDI engines were tanks as was the 7.3 PSD. The only reason those were more expensive to work on than a gas engine was because the components are stronger and built to take more abuse. Kind of a "get what you pay for" thing. The work itself wasn't so bad. The IDI engines had plenty of room to get to things under the hood. The PSD is a lot more cramped, but no more so than anything else in its day. While I really like the old ford engines, the 12 and 24 valve Cummins beat them in every way hands down. Kind of ironic that all of those engines were built within about 50 miles of each other... I've known a few engineers who work on the Cummins engine. I asked one of them once what made their engine better. His answer was that the Navistar engines were designed and built to use in trucks. A truck engine spends a limited amount of its life running at wide open throttle, and doesn't see conditions where the are maxing out their HP or TQ for extended periods of time. Conversely, the 6BT is an industrial/agricultural engine and was designed to spend its entire life running balls to the wall. Put an engine like that in a truck, and it will run forever (or at least until the EPA ruins it). I'm not sure if this is true for the current Cummins or not, but up through the last model, they were still using the same block that they were selling to Dodge back in the late 80s.
/ F550? #20
I looked into buying a used diesel truck. The older Fords and Ram trucks seem like the best things out there, but I don't want to spend my time rebuilding anything, or wrenching on it. Prices are horrible, but just about everything on those trucks are worn out. They need new interiors, seats, body panels and all of the running gear replaced to be reliable. For me, I'm going to pay what it costs to have something that I don't have to work on, wonder what will break next.
2018 Freightliner Cascadia 126 Sleeper Truck, VIN # 3AKJHHDRXJSJW6608 (A61165)
2018 Freightliner...
Wooden Three Headed Native American Statue (A61569)
Wooden Three...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
2020 John Deere 1770NT Planter (A63109)
2020 John Deere...
New/Unused Wolverine Mini Skid Steer 3 in 1 Bucket (A61166)
New/Unused...
Great Plains UT5052 Vertical Tillage Tool (A63116)
Great Plains...
