RK55H Hot Gas Tank
/ RK55H Hot Gas Tank #11
Which makes me wonder if RK is planning on updating their line of tractors since the current series they sell have been discontinued last year.
/ RK55H Hot Gas Tank #12
I had to Google if liquids get hot when compressed. I always thought of liquids as incompressible, which is mostly true. Compared to gases they don’t compress much but enough to generate heat. Not as much as gasses but when the fuel gets compressed it heats up, the excess returned to the tank, and this happens over and over I can see how it gets hot.
/ RK55H Hot Gas Tank #13
Seems the hot tank is the least of ones worries. Wow.
AI Overview:
Common rail diesel engines have fuel coolers to prevent fuel degradation and maintain optimal performance. High-pressure fuel injection in common rail systems generates significant heat. This heat can degrade the fuel, leading to deposits in the fuel system, reduced lubrication, and potential damage to fuel pumps and injectors. Fuel coolers help to dissipate this heat, ensuring the fuel remains within acceptable temperature ranges and maintains its lubricating properties.
/ RK55H Hot Gas Tank #14
A lifetime ago I worked in R&D for a pump manufacturer who made pumps for Navy and commercial ships. We would set up test rigs for them. Just pumping water through a test loop in/out of a ~10k gallon test tank could heat the water to the point of boiling it if you let it go as is long enough.
/ RK55H Hot Gas Tank #15
Maybe you could pipe in a fuel cooler. Pressurizing a liquid will cause it to heat up. On fire trucks the water in the pump would heat up past the boiling point and cavitate if we didn't have water flowing, to the point of destroying the impeller. My NH WM75 22 gallon fuel tank is in the same location as your tank. My tractor does have a fuel cooler. Must be why I never noticed any heat when climbing out after mowing.
/ RK55H Hot Gas Tank #16
You said you could only hold your hand on the tank for a few seconds due to it being hot.
Consider this, your shower water set at 120 degrees will almost scald you so you must really use your temp gun to find out how hot it really is before condemning anything.
Temperature is relative to animate objects (people).
/ RK55H Hot Gas Tank #17
It’ll be another two weeks before I mow again but I’ll let you know. I will say I could only hold my hand on the portion of tank below the liquid line for a second or two before the pain was too great, so my guess is it had to have been in the 130-150 range.
You might want to consider running it now to check the actual temp so you could address/fix the issue if necessary before you need the unit again.
/ RK55H Hot Gas Tank #18
The heating is a function of the pump inefficiency. If a pump is 90% efficient the 10% becomes heat. Might look at an inline oil cooler.
Patching the tank: Get a plastic welder, basically a heat gun with a feed tube to feed plastic rods onto the plastic your fixing as it melts the rod, and part your fixing. Odds are the tank is HDPE, and kits to weld it are readily available. Same basics as stick welding. But leave the bead proud, and clean it up with a sharp block plane.
/ RK55H Hot Gas Tank #19
I’ve got an Rx6010c with 540hours , bought new , left tank started leaking around 460hrs. I took it off (priced a new one $500+) so I rigged up an air hose to it, applied about 15lbs pressure, , found the exact spot of the leak.
Cleaned the area squeaky clean, roughed it up, cleaned again and used an old plastic fuel container that I cut in thin strips to use to “weld” with. I used a soldering gun and fused the seam together, then packed or spread the melted plastic on top of all that. I used an old bike tube as a cushion for the strap on top of the original and put it back on. I figured if I bought a new tank, I’d be out the $500 again in a few yrs, so I decided to do a fix. So far so good. Bad design on Kioti imo
/ RK55H Hot Gas Tank #20
I've found that I can *gently* hold my hand on 140-145 degrees F, but I can not, even gently, hold my hand on above 145. I can't imagine above 145 being allowed in a plastic tank. But... I'm not a plastic expert.
2016 Troy-Bilt 18in. Push Mower (A60352)
2016 Troy-Bilt...
2018 Ford F-350 (A55973)
2018 Ford F-350...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
(4) MJ Fittings (A60463)
(4) MJ Fittings...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
