Gooseneck for 150/1500 truck
/ Gooseneck for 150/1500 truck #31
😂 Any correlation between the towing and tranny R&R ?
We put all kinds of coolers on them but never occurred to us to install a temp gauge so we could witness the slaughter!
  • Good Post
Reactions: D&D
/ Gooseneck for 150/1500 truck #32
:ROFLMAO: Yep, that is a pretty important number
/ Gooseneck for 150/1500 truck #33
Good call, we have all the manufacturer data available here.
For my configuration of F150 (crew cab, 6.5' bed = 157"wb, 3.31 gears = not max-tow) my conventional bumper tow is 11.2k but the 5th wheel tow rating is 10.1k, interesting.
But for the 3.73 gears (max tow) the rating is the same at 13.7k for either bumper-pull or 5th wheel.
/ Gooseneck for 150/1500 truck #34
I've never towed with a goose neck. Are there any differences to a 5th wheel other than the side to side flexibility?
/ Gooseneck for 150/1500 truck #35
Keep in mind that when looking at tow charts they often don’t apply to your truck. Often in fine print it says when properly equipped. You can tow about anything with a half ton. Is it safe and legal is another question? To make a gooseneck or 5th wheel practical you need a payload approaching 3000 pounds.
/ Gooseneck for 150/1500 truck #36
You mean between a 5th wheel and a GN?
A GN has a ball which can be mounted below the trucks bed, allowing more open cargo space when towing. It also allows more while towing because the 5th wheel apparatus is pretty large.
I would actually like a 5th wheel for a change someday, but I don’t think I can sacrifice the bed space.
/ Gooseneck for 150/1500 truck #37
I don’t like giving up the bed space even for a gooseneck. I have a 30ft gooseneck but I can haul nearly the same load using the flat bed and the bumper pull trailer.
/ Gooseneck for 150/1500 truck #38
I don’t like giving up the bed space even for a gooseneck. I have a 30ft gooseneck but I can haul nearly the same load using the flat bed and the bumper pull trailer. View attachment 3941856
I couldn’t match this GN load of hay with a bumper pull and loading the bed.
If I shifted 2 bales of the 16 onto the bed, that would leave 14 bales. There’s no 20,000lb GVWR trailer that will carry 14 large bales without being overweight. Heck, the 14 bales weigh 12 tons alone. Even if I put 4 on the truck, and 12 on the trailer, the bales would weigh over 10 tons.
A 20,000lb GVWR trailer usually has a payload max of about 8 tons.
I hate the way a fully loaded BP feels compared to a fully loaded GN. The GN’s ride & handle nicer, putting more weight on the trucks front axle than a BP.
/ Gooseneck for 150/1500 truck #39
My baby load (about 5k) on my bumper pull.:)
/ Gooseneck for 150/1500 truck #40
If I had a 15 ton trailer it would be a different outcome but the weight capacity of the bed and bumper pull trailer combined is about the same as my 22k gooseneck trailer. This is not my truck but I really want to do the same thing with my Volvo. The Volvo is head and shoulders apart from the F-550.
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
2013 Chevrolet Silverado 1500 Ext Cab Pick-Up Truck (A60352)
2013 Chevrolet...
MULTIQUIP  LIGHT TOWER (A60736)
MULTIQUIP LIGHT...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2008 FORD F-550 SUPER DUTY (A60736)
2008 FORD F-550...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
