Buying Advice Kubota L5450
/ Kubota L5450 #1
Cowichanblue
Looking to buy
Hi all,
I’ve read a lot of good threads (some 20 years old, impressive forum longevity) on here but haven’t seen quite the answer I’m looking for.
I have a small property (2 acres) with some challenging terrain. Fairly steep slope in one area, small orchard and low seasonally wet area that sills be farmed in the dry.
An acquaintance is selling a 91 or 91 L5450 4wd with FEL and grapple on the loader plus a variety of implements. ( he’s Also selling a 1969 MF30 back hoe as a sort of package, but let’s set that aside for now) The Kubota has new rear ag tires but about 4,000 hours.
As I type that number it sounds very high. Based on who the seller is I believe, but will have to verify, that the machine has been regularly serviced. I’ve also heard these are some of the best Kubota diesels so maybe it still has lots of life. Still that seems like a lot of hours.
I won’t be working it hard or regular. Just odd jobs all the time.
Asking price is about 15k cdn for the Kubota and 18 for the package (Kubota and Massey Ferguson backhoe)
Question I have, is it even worth thinking about a 30+ year old tractor with that kind of hours no matter how good the engines reiteration and how great the service might have been? Do these machines last like heavy industrial iron where 8-10,000 hours is normal?
Appreciate any insight. I have some photos but can’t figure out how to upload.
/ Kubota L5450 #3
I asked a John Deere service manager for his honest opinion on how long compact tractor diesel engines last - he claimed about 4,000 hours. Kubota diesel engines are some of the best out there, so who knows how long this particular one will provide reliable service.
$18,000 CDN is a reasonable price though and you won't find much around for less.
It's only an opinion but Japanese engines will not last like the industrial/agricultural iron of the past.
/ Kubota L5450 #4
4000 hrs is a lot. The engine will need a rebuild and I'd suspect the transmission would need some work too. Maybe if you were a light user of 50hrs a year it'd be ok. Otherwise I'd look for something newer and less hours if you actually are going to really use it a lot.
/ Kubota L5450 #5
It’s hard to compare compact tractors to serious ag tractors or construction equipment but those 4000 hours would not be considered high for them. I think a careful look at it for bad leaks, smoke on start up, broken parts might let you know if it’s good.
/ Kubota L5450 #6
~117 hours a year is also not all that much. The price is about $11k USD or $13k USD for the backhoe. That's probably on the high side given the current market conditions (Area dependent). Except for the box blade, the implements certainly look well used. But given the sizes, it looks like they were primarily garden tools. (I also don't see a grass cutter.)
The Kubota with loader would spark my interest. A good test is if it starts quickly without being warmed up first. And check the inside of the air filter canister for a sand blasted look (frosted metal). That alone can show if it spent a lot of time in the dirt. That's a lot of tractor for two acres though.
/ Kubota L5450 #7
I just recently bought a 2005 Kubota L5030 with 3900 hours on it, starts in less than one revolution, no smoke, clean fluids and clean tractor, with honest wear, was used by the local state college to mow and spray . . .I paid $16,000 US for it ... Cab, but no loader ...
/ Kubota L5450 #8
Trying to add link to photos
I've bought older well-cared for machinery all my life, so that is my bias. And althogh I won't do major work, I do enjoy doing some mechanical work myself...always have.
In buying older machines, I've come up with a few rules that have worked for me.
Number one is that an old diesel should start immediately from cold. That quick starting ability is the best way i know to judge if an engine is good or worn. It should then run through the gears and all systems work. If that isn't the case, just walk away. Run it around awhile to insure it does not overheat and that the cooling system doesn't leak. It's my belief that more tractors are ruined by over-stress and overheating than by age.
So I'd say ignore hours and concentrate instead on condition. The design of machinery has changed a lot in the last 30 years. Before the modern throw-away era, older machines - whether machine tools, or tractors, or implements, were basically designed to last a lifetime and be repairable. Yes, routine maintenance and some repairs were a part of that philosophy of design. But the machine was expected to last.
You asked, "Question I have, is it even worth thinking about a 30+ year old tractor with that kind of hours no matter how good the engines reiteration and how great the service might have been? Do these machines last like heavy industrial iron where 8-10,000 hours is normal?"
Yes, they should. Not all do. Again, it all comes down to how they have been treated and the condition that they are in. Our older JD farm tractor - a model 530 - had over 10,000 hrs when we bought it. It still runs fine. I've done a clutch (easy on that model), brakes, muffler, & rebuilt the carb. It's been reliable for over 35 years now, and it was nearly that old when we got it. .
Our big backhoe - a model 310SG - had just over 5000 hours when purchased in 2014, and now has near 6000 hrs. Everything works fine. I replaced some hoses, tires, and the computer in the last 12 years.
Expect tht older machines do require more attention....no denying it. But they were built to make routine work easy to do.
So if you go with older machinery, check your own expectations. Do you enjoy doing small mechanical projects? Do you have a "mechanical" interest, tools, work space?
Next thing is to stay with brands where parts are not only available but reasonably priced. The more popular models still have new parts available. If concerned, check sources like Yesterday's Tractors, and Steiner Tractor parts to see if your tractor is one that they list parts for. I doubt you will have trouble with Kubota and Massey parts. Lots of older examples of both are still working.
It keeps coming down to condition. If the condition is poor or even average I'd run away. But if the condition is above average, everything functioning, with maintenance notes, and maybe even some manuals and such...... then I think you can reasonably expect that an old machine will work for years much the same as they do right now.
The old machine has lasted this long. If you treat it right, no reason an old one won't continue just as it is.
rScotty
BTW, that is quite a pile of implements in your photo. Are any of them useful on your property?
/ Kubota L5450
I appreciate all the replies on here. Great to see an engaged community.
I'm going to look at the machines tomorrow and hope to have some more information then.
In answer to the questions above.
Implements, the box blade and tiller would be useful. Not sure about the rest.
As tinhack noted, no grass cutter is a shame. I have a basic ride on now but a bigger cutter would be useful.
In terms of intended use, I have a small pond I would like to expand. I also have an old building that may need to be demolished. Quotes on that are around 20k, so if the MF30 could do that job then it might pay for itself.
Lots of fencing needs to be put in (3 sides need it), but would need to add an auger for that. Otherwise General maintenance, ploughing a small field, ditching, leveling, grading. Occasional snow removal. The property was abandoned when we got it so endlessly fighting aggressive invasive weeds.
/ Kubota L5450 #10
I'm considering getting a "post pounder" for mine, as I also have fencing to do ... I'm not crazy about PHD's ...
/ Kubota L5450
Got a look at them tonight, but it started raining pretty good while I was there so didn't have nearly as much time as I hoped. Both machines started right up, first crank and no smoke I could see. Both sound like the run very nicely. Fluids look good from what I could see before the rain kicked in. The Kubota has clearly been used but apparently regular maintenance at the local dealer. I'll be following up on that. The Massey has been more of a "it sits and works when needed". Seller says he does basic oil service and not much else as it doesn't get much use.
I took a few photos that show some more detail. Not sure that anyone on here will have much they can tell me, mostly wrestling with price. Hard to find comparable numbers, especially for the backhoe. Seems a working one (any brand any condition) is never listed for less than $10,000 CDN in my area. From reading up on these I know the swing gear is a common trouble spot. NO visible leak there or on the other hydraulics, but clearly some oil around the engine case. The tires on the MF30 are starting to dry rot, maybe those photos can give an indication on how much life might be left in them. I am not wanting to put $3-4,000 into tires. I would likely be using the hoe for a year or so then trying to sell it again.
The Kubota is nearly as hard to price. Only similar one I can even find listed at the moment is an older model, lower hours but turf tires and a backhoe for $21,000 CDN.
By that math the asking price here ($18,000 CDN) for both machines is quite reasonable. Think I'll try to arm twist a friend or bring a mechanic up with me on a nicer day to give them a better run around.
Many thanks for any input/advice.
/ Kubota L5450 #12
I have low, low hour L5450 with a Bradco hoe, without looking, it has somewhere around 500 hours. Barn kept, a beast and my favorite tractor. Low hours due to being on a remote property. That 5 cyl engine is SMOOTH and never needs glow plugs in our marine climate (down to 15 F).
/ Kubota L5450
Talking about my dream machine right there.
2012 KOMATSU PC360LC-10 EXCAVATOR (A64279)
2012 KOMATSU...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
2004 INTERNATIONAL 7400 20FT T/A FLAT BED (A59910)
2004 INTERNATIONAL...
Gradall no crank no start (A61568)
Gradall no crank...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
