O'Reilly Auto for hydraulic hoses
/ O'Reilly Auto for hydraulic hoses #1
pretendfarmer
Gold Member
WA
John Deere 790
I have had 2 hoses made at O'Reilly and am having massive sticker shock, wondering if they are intentionally fleecing me. The last one - 8' of 3/8" with 2 JIC fittings was $152. Does that sound right?
I was looking on Tractor Supply's website and I can buy an 8' section of 3/8" hydraulic hose with male NPT ends for $35, and two 3/8" female pipe x 3/8" female JIC swivel fittings for $20, totaling $55+ tax. I wanted to get some opinions. I did not realize I could get it from Tractor Supply until after I bought it and installed it.
/ O'Reilly Auto for hydraulic hoses #2
Look for a hydraulic hose shop in your area. They can custom make hoses with fixed, instead of swivel ends, pretty inexpensively. My local guy even made a 50’ replacement air hose for my shop with goodyear rubber cheaper than Home Depot chinese hose.
/ O'Reilly Auto for hydraulic hoses #3
$152. Does that sound right? Not really, but it seems some places charge whatever they want for making hoses these days. I've been charged $80 for a 1/2" hose 18 inches long (with metric hose ends). I've used TSC for ready-mades on occasion when budget for the project justified it. Biggest problem I have with that is they only stock a maximum of two of anything. If you need three or four hoses you have to drive to another store in another town.
/ O'Reilly Auto for hydraulic hoses #5
I've always thought of O'reilly as an an Auto parts store with higher prices. I assume the hydraulic hoses you needed connect to a Tractor so it would be logical to look at TSC first. I had some custom hydraulic hoses made at an Ag equipment dealer closer than town and they also must be made out of gold at their prices.
/ O'Reilly Auto for hydraulic hoses #6
Yeah, but air hose fittings are a lot different than hydraulic fittings. By about 15,000psi. I make my own air hoses as well. Mostly for short runs between machines with tees and blow guns. I have a crimper and box full of fittings and crimp sleeves for various sizes of rubber hose. The fittings are brass.
The Goodyear air hose is one of the worst I've experienced. It rots and cracks on the reel. It's probably made overseas too. The best hose I've found for inside shop use is the black rubber hose at Harbor Freight. It has lasted the longest. For outside hose, the blue vinyl coated hose. I've got a couple of 50 footers that are over 10 years old. And they live outside.
/ O'Reilly Auto for hydraulic hoses #7
I've been fleeced by the local auto parts stores on hydraulic hoses in the past, when I had to get the tractor going NOW. When I can catch hoses getting in rough shape as I did just this past week when I rebuilt my toplink cylinder I order from Surplus Center. I ordered the 2 toplink hoses and they were only $9.55 each - 1/2"x 24"x 1/2" NPTM. Shipping sucks but was not over the top. Probably would have cost me 3 - 4 times as much to get them locally. Fortunately I caught the old ones before any leakage.
/ O'Reilly Auto for hydraulic hoses #8
You might get a hydraulic hose made a bit cheaper at a hydraulic shop, but most of them keep Monday to Friday operations and 8:00 - 5:00 hours.
So if you need to have a hose made after hours or weekend you stuck with who’s open.
If you need a hose with 90 degree swivel fittings, specific length or non pipe threads then you are out of luck at TSC for the most part.
It costs a bunch to stock all the fittings needed to make hoses and may not sell them regularly.
Also now most places are tacking on a labor fee to make hoses.
/ O'Reilly Auto for hydraulic hoses #9
If you know exactly what you need for hose size, fittings, and length, @kennyd at BoltOn Hooks will make them for you at reasonable prices, great quality, and will have them to you fairly quickly (although I see you are on the other side of the country).
/ O'Reilly Auto for hydraulic hoses #10
Fortunately there's a REAL hardware store about 1/2 hour away. When I was plumbing the snow plow lines they made up two hydraulic hoses in their service department in about 10 minutes. I forget the cost, but remember it was very reasonable.
/ O'Reilly Auto for hydraulic hoses #11
The hose is the cheap part. You are paying for the fittings at the end of the hose. $150 seems expensive to me. I own an old backhoe that's full of hoses and I need to replace several of them every year. The most expensive one that I've ever had done was over $300, but on average, they are under $100
I go to a hydraulic hose company called Aaxion here in Tyler, or Longview TX. Parker Hannifin Hose, Fittings & Connectors | East Texas | Distributor They are only open business hours, so when I've been desperate for a hose on a weekend, I'll go to Napa. I didn't know about O'Reilly, but now that I do, that will be an option for me. If I really need that hose done right away, then price isn't my main concern.
If the fitting is a flat face, be sure to install a brand new O-Ring. I have several kits from Amazon that have every size I've ever needed.
The last hose I replaced was just a couple weeks ago. It cost my $85. It was on the boom of my backhoe, and so tight next to the other hoses that I had to remove a hose to get to the bad one. When I put it back together, I replaced the O-Rings with new ones. For me, the fittings for both hoses took a total of four different wrenches. They make them different sizes, so you don't cross one hose with another.
/ O'Reilly Auto for hydraulic hoses #12
TSC website shows that size hose for $18. Local store has only one in stock. If you need two, you're out of luck.
/ O'Reilly Auto for hydraulic hoses #13
What does O'reilly show?
/ O'Reilly Auto for hydraulic hoses #14
Not sure but I don't think they carry ready made hoses. As far as them making custom hoses, I would think that's an individual local store type of thing.
/ O'Reilly Auto for hydraulic hoses #15
After learning my lesson the hard way I have saved major $$$ by buying replacement hoses from Fleet Farm stores, they have a very nice selection of brand new ready to go hoses on the shelf. Not sure but I think they also do online sales.
/ O'Reilly Auto for hydraulic hoses #16
Well, my goodyear rubber hose is over 10 years old. Its red and still looks like new. This same company made all my hydraulic hoses for front snowblower, plus has made repair hydraulic hoses for me for past 29 years. As long as i supply them with old hose, they will make me exact copy. The ones they make feel alot heavier than the originals. Ive compared prices with them and auro parts houses and dealers. There alot cheaper. As far as i know, the others bring the hoses to them to make in the first place?
As for the air hoses, i realize there lighter duty. All i was saying is they will make them far less expensive than home depot or lowes prices. I e never used harbor freight hoses, cause i stay far away from their stuff for the most part. Except for their tool boxes, i have not seen much quality stuff at HF.
/ O'Reilly Auto for hydraulic hoses #17
If you can wait to have it shipped to you, take a look at the Surplus Center. I have gotten a couple from them. This may not be your exact hose but can give you an idea:
Thank you all for the replies. I will only use them again if I absolutely have to.
/ O'Reilly Auto for hydraulic hoses #20
I just got hoses from Discount Hydraulic Hose in Pennsylvania. Good price & service.
I agree on Discount Hydraulic Hose. I have used them for years for both fittings and hoses. They are very good with price and service !!
Their custom hose service is especially good.
But last spring I blew the pressure hose on my wood splitter. Didn't want to wait and needed a hose good for 3500 psi working pressure. The local O'Reilly makes hoses so I went there. In 15 minutes they made me up a 5 foot 1/2" 4500 psi hose with NPT fittings for $75. I was a happy customer back to splitting wood in an hour.
gg
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
2012 Peterbilt 337 S/A 16ft. Cab and Chassis Truck (A64194)
2012 Peterbilt 337...
2019 John Deere 314G Compact Wheel Loader Skid Steer (A64553)
2019 John Deere...
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
