jwmorris
- Joined
- Oct 3, 2007
- Messages
- 1,140
... and I ran it for a tank of gas and changed the oil (inspected and), I think it looks like it might run for awhile but I didn't really need it. I have other stuff sitting around like a 1/2" QD plate 3x8.5 box tubing, pillow blocks and drive shaft material to connect to the 10 HP right angle mower gear box with an arbor I machined to attach one of the lot of 18" industrial saw blades I "won" along with something else I really wanted.
I thought throwing them together (maybe as a bolt on to my hay forks) and making a gas powered lane saw. 7.25" blade on floor for scale. Need to roll that 2" flat strap a bit tighter too
Even have some loops of box tube to make a limb guard (not likely to get replacement parts quickly, unless it's just swap to the next one it's $79).
Have to keep it pretty level for proper oiling but I need to remove the electric start switch box from the engine anyway to get it closer to the tubing (3 bolts) and either extend the wires or probably make it wireless remote controlled. That will allow me to have the engine and blade stopped until the moment I am ready to cut, if I am not continuously cutting.
I'd like to use a different style pillow blocks for the drive shaft, I'll have to look around some more and see if I have more of other styles. I'll broach my coupler tomorrow for the key.
Think I'll shoot my eye out?
