Your opinion of 4310 with 430 loader
   / Your opinion of 4310 with 430 loader #1
coloradotrout
Gold Member
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
Thoughts on reliability?
Any particulars to look at on 600h used one?
Suitable to run 5' tiller, 7' finish mower, 6' rotary cutter, 6' box blade , maybe 1 or 2 bottom plough , 9' sickle mower
   / Your opinion of 4310 with 430 loader #2
I’ve used the 4310 with the 430 loader quite a bit, and honestly, it’s a solid, well-balanced compact tractor. The power-to-size ratio is great, and with regular maintenance, they hold up really well. The loader is smooth and strong enough for most small farm or property jobs.
   / Your opinion of 4310 with 430 loader #4
We had a 4310 w/430 loader had a little over 1700 hours when it left our place. It's still going at its new home.
A 2 bottom plow did not do well in our clay soils. The other stuff, didn't have any issues. I'd get another one.
   / Your opinion of 4310 with 430 loader #5
OOps, should have added; it won't run a 7' finish mower in 12"+ grass/brush. It won't run a 6' brush cutter in thick cover below 2000 rpm. It won't till really well below 2000 rpm. It won't fill up a 6' boxblade very well without using 4 wheel drive ;)
Thank you. Yeah I figure I'm right on the edge with a couple. 5ft brush cutter might be better. 5ft box blade. I assumed I'd need mfwd for box blading.
Reasons for me to upgrade from a 4100 CUT to the likes of a 4310 are to brush cut or sickle cut 40 acres 2x a year. I don't need much heavy brush cutting. I've been getting along with my 4 footer. I just want a wider cut to reduce time Also to run the 5 ft tiller that barely gets by on the 4100. And to break up clay in the arena with teeth on the box blade or similar.
I've been looking at a Branson 4815 or 4215. The 4310 seems to be about the same specs. The 4100 has been solid minute the engine piston fail as a result of original owner fault. Still, it ran for years.
   / Your opinion of 4310 with 430 loader #7
I'd seriously consider a rhino ts10 flex mower.
   / Your opinion of 4310 with 430 loader #8
I've had my 4310 for about 10 years now and it has been a great little tractor overall. I have the power-reverser model and it has done everything you mentioned. I run a 5 1/2 foot drum mower on it and I can run it range C gear 2. I also use it quite a bit to run my 273 NH baler. Adding ballast to the rear tires and adding 2" wheel spacers made a world of difference in its stability.
2007 Ford F-150 Pickup Truck (A50323)
2007 Ford F-150...
19200 (A50324)
19200 (A50324)
John Deere 960 Culitivator (A50514)
John Deere 960...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2010 Triple B Gooseneck Inclosed Car Trailer (A50514)
2010 Triple B...
Komatsu Pc200lc Excavator (A50514)
Komatsu Pc200lc...
